TrueRTA questions...
  • ABlakeG
    • 3
    Hello there. I have reached the point where I feel that I need to address my room before anything else (component upgrade and whatnot). I bought the following programs to aid my journey --
    TrueRTA level 4
    ETF (with mic and preamp -- not yet received)
    My associated equipment is Lexicon MC-12B v4 (room EQ), ATI 3007 amp, Dynaudio Confidence 2 speakers, and 2x SVS PB12+/2 subs (run as right and left subs from the Lexicon)
    My room is 12x14x9, 5/8 drywall over 2x4 studs, which are attached to concrete (room is mostly underground)
    I am also using a Behringer ECM 8000 mic and one of their preamps to supply power in the interim. I used my computer sound card, which tested properly in the self test, so I assume that the mic in and line out were working OK. I played some sweep tones through my system, and here is the resulting graph -- I think that it is accurate, but that is what I am asking help with. I would like to use a BFD to EQ my sub flat. This measurement was taken in 2 channel, with subs engaged, crossed over at 60hz. The room EQ, which supposedly works only on resonance in-room, was engaged. I used my normal volume level, which is -15 below reference on my volume control.
    Sorry about the readability of the graph -- it is from 50hz - 10hz, 1/24 octave.
    Does this look like reasonable low-freq response? I think that it is too high -- I know that the subs I have are pretty capable, but this just seems like too good to be true. I just want to know if I am reading this right, using the software correctly, etc.
    Thanks for any help or suggestions.
    Blake
    Last edited by theSven; 25 June 2023, 22:27 Sunday. Reason: Remove broken image link
    • 10931
    You can change the colors in TrueRTA so that it's easier to see. Also the bar graphs are easier to read.
    Turn it off and remeasure. For a sub 1/12th octave is all you need. And turn down the level, you only need 80-85dB output for testing purposes
    • ABlakeG
      • 3
      Thomas --
      Thanks for the suggestions. I must be stupid, though. Last night I went to measure my response again, and I was getting levels in the 110+db range, and it was barely audible through my speakers. I am beginning to wonder if I have the set-up correct? I was using sweeps from 100-10hz, and controlling the volume on my pre-amp. The lights on the Behringer mic pre were barely lit (the signal level lights) and yet it was measuring huge numbers.
      To make sure that I have this correct, I go mic-micpre-mic in on sound card, and the line out(analog) - analog in on my lexicon. that should be right, correct?
      Thanks for any help. Sorry for the basic questions. TrueRTA said to max out all the levels in my computer -- should I be adjusting those?
      Blake
      • Bruce
        • 156
        I don't know about your soundcard, but technically you should be using LINE-IN (NOT mic-in) on your soundcard, because you input is coming from the LINE-OUT of the mic's preamp. In your PC's sound mixer control panel, you should actually have the the slider for the mic input turned off (MUTE).
        Bruce
          • 10931
          That's for calibrating the soundcard.
          You use the volume control of your pre-amp or receiver to set the SPL from the woofer.
