Jon Marsh mentioned in another thread:
" I finished a dual 18" Avalanche LT design that was previously requested today. There is FRD consortium workshop XL sheet, but it's not exactly user friendly."
I've been trying to use this same spreadsheet to do exactly the same thing... come up with a design for dual Avalance 18's in a smallish (6-8 cu ft box) design. I'm looking specifically at using the adire ada-1200 whcih would deliver 600W in the 8 ohm load. My reasoning for doing this was that the ada-1200 appear unable to drive the avalanche 18's into overexcursion even at full power under 10hz (I'm more concerned about protecting the drivers from overexcursion than driving them to max at more reasonable frequencies, 30hz and up)
so my question... it appears from the spreadsheet (dual 18's, 8 cu ft, Q=.58, 600 W into 8 ohms) fc=14hz, f3=17.7) that the combination puts out about 112 dBspl at 100 watts input.
It also appears that the amp runs out of juice attempting to maintain 112dBspl (at whatever input level drove it to 100 watts at say, 40hz) at around 21-22 hz. It also appears that excursion is around max at 600 watts at around the same frequency.
So my questions:
1) Am I reading the spreadsheet right? Is the ada-1200 (600w into 8 ohms) a "safe" amp for 2 avalanche 18's, in terms of over-excursion?
2) Are there any more specifics on your dual 18 LT design that youre willing to share?
A suggestion... is this is a viable design, Chad should post it on his site.
I registered just to ask this question BTW... happy to be here.
thanks in advance for any answers you can give
David.
So my questions:
David.
