Inductor size question
  • DeanP
    • 175
    Dan Wiggins has designed a speaker using CSS' new WR125S 4.5" driver with the Audax TM025F1. In the crossover it calls for 0.11mH 20 gauge (0.130 dcr), I looked all over and could not find a 20 gauge with those specs but I could find a 16 and 18 gauge with the same mH and dcr. Could a person use the larger size?
    The design link is at CSS' website...
  • soundhound
    • Mar 2004
    • 815
    Yes, the frequency is inductance dependant and the guage is load (current) dependant. It sounds like you know the numerically lower the guage the larger the current capability.
      If the larger gauge has the needed DCR then it's fine.
      • DeanP
        • 175
        Thanks guys! Now I am a little bit more knowledgeable... :W
