I recently bought an NS15-992-4A woofer from Aurasound because I loved the sound of it's sibling in the MDesign's Godfather subwoofer. If you have a chance to check that sub out....i would so go do it. It was rather impressive. The driver specs have been attached below. I am currently trying to decide what allignment to use and I"m torn between the vented/sealed allignments. The vented allignments require massive vents which makes the boxes a bit awkward. Not that I don't mind large subs...my current one is about 8ft3, but I can't seem to make the dimension look good. This has brought me to consider a sealed allignment, which is what the Godfather subwoofer uses anyway.
My question is this....can anyone tell me how adding EQ to driver effects it's excusrions plots? I did some reading last night in all my audio books, and could only find a paragraph in passing about it, but was hoping to get more details. What equations govern the increase/modification of the cone excurions with additional EQ?
I also read that adding EQ changes the phase of the response rather dramatically as well......how does this affect the sound of a driver in practical terms? Can this me mediated by setting the subwoofer to a nearer position in the processor?
Just FYI...I will be using an Adire ADA1200 amp to drive the system.
