Data usage question
  • madmac
    • Aug 2010
    • 3122
    Data usage question
    Attention computer expert people !!
    This may sound like a dumb question to some people but I will ask anyway.
    I have no wired internet at my apartment and all my devices at home connect to my phone's WiFi hotspot and feed off my phones data plan (Phone/laptop/printer/ PS3). My phone delivers 54.0 mbps wireless according to my laptop.
    My question is this....... If I watch Netflix, YouTube or listen to spotify on my PS3 does it use more data than if I did the same thing on my phone itself?
    Let me know?
    Thx.
    Dan Madden :T
  • Kevin P
    • 10808
    It depends... if you watch a 480p stream on the phone and a 720p stream on your other device, then yes, the other device will use more data. Also phones sometimes use lower bitrate streams. A good test would be to note how much data you've used, then stream 10 minutes of something on the phone, note the data used, then stream the same thing on another device, and compare the amounts.
