I came home at lunch today, noticed the microwave blinking. So, we'd had a power interuption. My PC was quit, and it's usually running X 24. So, I turned it on, and it got to the windows boot screen, past the black and white one to the color screen (W2K) the power bar started to fill, and after one square filled in, you heard a click, and it rebooted. I had a new USB device online, that HP printer, so I unplugged my USB devices after going through that same thing several times. Finally after fiddling a bit, I got the blue screen of death:
"Inaccessable Boot Device, Restart if first time this has occured. Unplug any newly connected hard drives, etc. I had connected my new compact USB hard drive at one time, but disconnected it a long time before the machine went quit.
So, the USB based printer had been connected, no software installed. The HP 6310 had been installed with software, was functioning fine as a USB device.
Now, it's done this twice. First time today, to get to a point of total failure, I'd unplugged all USB devices, and though that had something to do with it starting back up. But it turns out, the blue screen of death is what allows it to restart. I did press F8 to see options, and I have the partition setup so it shows Windows 2000 as the only available system, I said boot normally, and wham, it crashed. But then the next time up, it comes up.
The message suspected a virus as well (but what the hell does winblows know?
I'm a little perplexed. It's rebooted now, not sure what happens if I shut it down and come back up again. I'll find out.
