Just wanted to let y'all know about a decent deal I ran into tonight. I was in Best Buy earlier and picked up a Maxtor 100GB external drive (USB) for $79. $99 with a $20 in-store coupon.
Maxtor 100 GB USB Drive
Tags: None
I made a 250GB Western Digital USB external drive for $60 when I was all said and done...
Sometimes it's better to buy the case itself and throw in any drive you want (plus you can keep throwing drives in), Maxtor and WD and the rest of them make it so it's extremely difficult to get the drives out.
-Dan- Bottom
Nope, just USB - no firewire.Originally posted by AzekeWow, that's pretty impressive from a cost standpoint.
Is it just USB or is Firewire included as well?.
I just got a 320 GB 7200 RPM OEM HD off Newegg for $121 shipped after $15 mail in rebate. I've got an external case to throw it in already, but I plan to use it to store DVDs to run through my media PC.AJPoe - - Growing old is inevitable, growing up is optional!- Bottom
This is a dumb question but when you throw the drive in a case, what do you use for a connection if has just the ATA or SATA style connection? This sounds like a much more cost effective way of adding storage than just an external only drive.____________________
Erik
Just another case of the man trying to keep us down! :B- Bottom
Cases are available with either IDE (ATA) or SATA interfaces inside the case. You connect your drive to this interface when you install it inside the case. Then you connect the case to your PC with USB or FW, depending on what the case gives you on the outside.- Bottom
by P-DubJust curious, has anyone had any experience with this unit?
I saw this at Costco for $389.99.
I'm looking to add an additional external drive for storgage. I'm interested in the network solution. I currently have a drive enclusure and it... -
by JonMarshwell, geez, it's a new year, and I haven't finished configuring and tweaking my last music player setup (AURALiC Aries with Mutec 1.3+ and AURALiC Vega DAC) and I'm already working on another one, a combination of pieces I've bought in the past and some new bits (pun intended) that should fit together...-
Channel: Digital Audio
by LexI know we typically think BIG, and BIG is BETTER when it comes to screens. However, I used some reverse logic with this decision. In addition to cost considerations, I made quality considerations. The set I opted for is the 55" curved front 9000 Samsung curved front TV. You may be saying, curved... -
by jim1961I only need 1 port actually since its only job will be to interface and power my WD 2TB Passport hdd drive. But 2 or 4 ports would obviously work fine also.
Basically, i just want to clean up the power arriving at the hdd and lessen noise leaking into the data stream.
Interestingly... -
Hi!,,
Last item I need for my DIY Computer is
a Hard Drive.
I recently bought a Quantum Fireball 40GB 8.5 MS
7200RPM for my old computer, which will stay put for now.
Other choices are the IBM Desk Star ,,not sure of the MS rating .
... - Loading...
- No more items.
