I had the opportunity to test out a Studio Experience Cinema 20HD LCD front projector last night. Here I will post my impressions after playing with it for a few hours. It will be installed in the owner's home this weekend.
Set-up was a cinch. I connected my Sony DVP-S9000ES DVD player to the component inputs and my JVC 3800 S-VHS VCR up as a cable TV source, via S-video. The PJ has three inputs. Input 1 is DVI or VGA only; input 2 is component or RGB video via BNC connectors; input 3 is selectable composite, S-video, or component via RCA connectors. Since I didn't have any BNC adapters I connected both my sources to input 3, and switched between them from within the projector's menu. I would like to have seen more inputs available, such as separate selectable composite, S-video, and component inputs.
(Shameless plug: that component video cable is a CatCables Tigress
Since I only have the PJ for a couple days, I just set it on my coffee table and hung a bed sheet from the ceiling to act as a screen. Once powered up, there is a ton of setup options available. The usual setup options are there, including floor/ceiling mount, front/rear projection, motorized focus and zoom, and a cool lens shift feature that allows you to shift the entire image up and down to align the image with the screen without having to tilt the projector. This minimizes the need for digital keystone adjustments, which of course are also available.
When feeding standard home-theater type signals to the PJ, all the usual calibration settings are available, including color temperature, contrast, brightness, sharpness (looks best if turned down all the way), color, tint, and various "automatic adjustment" features. Computer resolutions up to 1024x768 are available. Four aspect ratio options exist: normal (4:3), full (16:9 anamorphic), zoom, and wide zoom (used for non-anamorphic letterboxed DVDs and LDs). A digital zoom is available for computer or DVI signals.
So, how does the projector look? I have to say this is one of the best looking LCD projectors I've seen. I'm not a big fan of LCD, as they don't have the black levels I like. The 20HD won't compete with a top end DLP or a CRT, but it holds its own. This is one of the brightest consumer LCD projectors available, offering 2200 (max) ANSI lumens, which is important if you'll be watching in a lit room. I watched cable TV with the lights up in the room and it was very watchable. I wouldn't watch it in a sunlit room, but close the drapes and the PJ will still be fine for non-critical viewing. Save the movies for nighttime in a darkened room, for the best impact. There is a slight amount of ringing or edge enhancement visible in the AVIA Sharpness pattern even with the sharpness turned down. The "low" color temperature looked pretty close to 6500K to my eyes, but then I don't have a colorimeter to determine how close it really is. All the color temperatures are tweakable from the user menus, so ISF calibration of the projector shouldn't be too difficult.
Here's a shot from Toy Story 2. The distortions and creases in the picture are because I used a bed sheet for a screen.
The projector did a good job of deinterlacing even analog cable TV. It looked better than my 46" Mitsubishi HDTV looks on cable.
A shot with the lights up. This projector is bright!
No pixels or "screen door" was visible from a normal viewing position. The only other flaw I saw was a slight purplish tint at the very bottom left of the screen, about an inch high; perhaps something was blocking part of the green LCD panel. A blotch was slightly visible on black or dark scenes, probably due to dust in the optical path. This is probably easy to fix if you're daring enough to open up the projector. Chances are a non-critical viewer won't even notice these flaws.
In summary, the 20HD is a great projector for those who need FP in a room that doesn't have total light control, someone who wants to project their PC onto a big screen, or for someone who wants a flexible projector for non-critical viewing. More critical viewers will likely be happier with a newer DLP or CRT projector.
KJP
My HT Site
KJP
My HT Site
I don't have the manual or specs in front of me.
