I'm looking to buy an lcd widescreen tv for under $1000, preferably with 720p display capability.
I noticed that changing channels at the Best Buy (the ones out on the shelves that appear to only be connected to coax cables [is is still digital feed]...not the component connected ones in the "Home Theater" section, channel changing is locked on those) that channel changing is excruciatingly slow. I WILL NOT buy a tv if I can't change the channels fast! Having said that, if there's some way around the problem (for example I've noticed on my current setup that my current tv changes channels slowly but hook up the VCR and use the VCR remote to change channels and you're off and flying!), then maybe I don't care so much whether the actual tv remote changes channels quickly by default.
So my basic question is what do I have to do to get a widescreen tv that changes channels quickly? (the quicker the better, it's a big selling point for me) Because of my ignorance, I don't know if maybe channel changing is quicker/slower depending on whether you use composite, coax, component, s-video, or HDMI. I also don't know if all LCD tv's change channels slow (whereas I know that many CRT tv's can change channels at the speed of light). Lastly, I don't know if hooking up a VCR to the LCD widescreen tv will allow me to change channels quickly...and if so, are there VCR/DVD players that won't degrade the signal from HD to standard definition?
Thanks to anyone who can help me out.
