Hi. I have recently experienced a sudden volume drop in my center channel. ( I believe it happened after a heavy night of volume topping music listening) I have to have the CC gain at Max and the rest of the speakers set to around -6 in order to balance it out. And that still doesnt really work. I switched the CC to determine if it was the speaker. Then switched the R with the C in the output and ran the test tone. It is definitely a channel problem. Does anyone know if this is a simple capacitor issue that I can fix? I am savvy enough to, and have replaced components in other electrical equipment. Or, is my amp dead and or dying, and I need to find a new one. Thank you for your answers in advance!!
Cheers.
Cheers.
