NOTE: 06 April 2020, PROBLEM SOLVED!
Hi!
I'm new to the forum and also to the Rotel brand. I already had one system running with Marantz and another one with the Anthem MRX-500.
Recently I had the opportunity to buy a Rotel RSP-1098 and other equipments from some that was moving to a smaller place, so I decide to give Rotel a try.
I hooked up everything, it works as it should but I noticed that nothing was happen with the sub. I check if it as set to YES in the 1098 system and it was, the speakers were set to small and the crossover set to 80hz, but no sound yet. The processor has two sub outs but none of them are outputing anykind of sound, not even nice or hum.
I was using a DD 5.1 source to test, the signal was arriving in the processor using the optical cable. I decided to try the MULTI-IN analog inputs and the problem continues, no sub out even when I connect one RCA cable in the SUBWOOFER IN.
As I live in a small city and in a country were Rotel it's not very popular, I decided to open the processor to do a visual inspection, I found that on 35v330uf capacitor in the power board seems to be with problems (leakeage) but all other parts looks ok.
I have the service manual but I am not some one with experience in this kind of thing.
Some one has any idea of what could happening?
Thanks!
P. S. 1: I also have a Rotel RMB-1077 (class D ICEPower 250ASP and 250A) where none of the channels works and also don't make any kind o noise. It turns on, the protection light stays off, but no sound at all.
P. S. 2: Sorry about my English, I live in Brazil.
Hi!
Thanks!
