While listening to some music, the phone rings. I get up to turn down the volume, I turn the volume down (counter clockwise) from 68, the volume jumps to 74.
This is a random example of what happens once in every 12-15 times I turn the volume down. Once I had the volume around 63, cut it down, it jumped to 78! 78 is where I have the max set at so my 2 year old won't break the B&Ws.
There is a setting on the OSD so that when you adjust the volume it responds slowly, medium or fast. These adjustments don't fix the problem at all.
Also, it only seems to happen when I try to turn the volume down quickly.
Seems like a childish beef, but when you spend good money on good products this is unacceptable. I just took the DVD player in (1060) because every day it decides not to read 3 or 4 more DVDs.
Does this sound like a larger problem waiting to happen? Anyone else with this issue? Really don't want to loose my processor for 4-5 weeks only to discover the Techat Rotel can't duplicate the problem and send me back my defective unit.
Any advice?
Any advice?
