I have recently built a house. I wired 7 runs of cat 5e and brought them all to a central location. I am looking for a junction box, or something similar that would allow 1 input and 7 outputs. Preferably one that doesn't require crimped ends. They won't all be in use at the same time of course. Any suggestions? I'm having trouble finding what I need!
Cat 5e junction
Something like this? https://www.digikey.com/product-deta...626-ND/4834935
Lots more possibilities here https://www.digikey.com/products/en/...tches-hubs/927Lee
Paradigm Studio 60 v.3- Bottom
It is a punch-down block but you would probably be better served with a switch like this: http://us.dlink.com/products/busines...igabit-switch/Kal Rubinson
"Music in the Round"
http://forum.stereophile.com/category/music-round- Bottom
If not, here's a start https://www.google.com/search?rlz=1T...=1511574146434Lee
Alaric, thank you for the suggestions as well .- Bottom
Kal Rubinson
The punch down block and the network switch are two different things. A punch down block is used to connect the physical wires either to another set of wires, or to a set of RJ45 jacks. Then you'd use patch cables to connect the block to the network switch, which makes the network connections between the cables.
The other option is to crimp RJ45 connectors onto the ends of the cables in the utility closet and plug them directly into the switch.
Here's an 8 port punch down block: https://www.amazon.com/TRENDnet-Unsh.../dp/B003SSX1Q6 There are 16 port ones available as well, but if you only have 7 runs, you can get by with the 8 port.
Here's an 8 port Gigabit ethernet switch: https://www.amazon.com/NETGEAR-Ether.../dp/B00MPVR50A- Bottom
Thanks. I had thought that but was not confident enough to say so.Kal Rubinson
Thanks guys . I guess It makes the most sense to buy a crimp tool and some connectors and just set up a network switch. I'm sure the crimper will pay for itself over time. I have approx 800-900 Ft of cat 5e left over. I'll probably make a few cables up over the years, LOL.- Bottom
