I've been hankering to try a transmission line for a while. I realise many people use these for subwoofers and 3 ways, but I thought why not try it with a 2 way, using a low Qts driver to really make my job hard?
To make it even harder, why not throw an active crossover into the mix? I also want to experiment with faceted baffles.
The active crossover will take the form of a Raspberry Pi 3b+ with HAT attached Suptronics DAC which takes HDMI to 7.1 channel unbalanced analogue output via RCA (sadly these are NLA - so I better treat it nicely). I have a media server built on the same (albeit IQAudio 2 channel DAC). Using either Ecasound or CamillaDSP - I can implement the IIR crossover. Modeling may either be done in VituixCAD or Charlie Laub's Excel based tools (Charlie built these to produce the required ecasound parameters to apply the filters - so plug and play).
The drivers - SB Acoustics - so no originality awards here:
SB17NBAC-4 and TW29DN-8
Onto the enclsoure...
I modeled this using David McBean's excellent Hornresp tool. It takes a little getting used to the UI, but once you have the basics down, quite powerful.
I came up with a 2.6:1 (reducing) taper transmission line ~ 43 litre volume (169cm line length). This is quite a bit larger than the many vented options but the TL gives a theoretical F3 of 35Hz.
Now I know this isn't going to win any SPL awards, so will be volume limited to about 25w with bass heavy music. They'll be used in a smaller listening space and are experimental, so I am happy with this compromise.
Here's the HornResp model with stuffing to smooth the TL ripple. I used a path offset of 64.2cm being the distance between SB17NBAC centre and terminus centre:
NB there is no baffle step rise in this modeled response - so expect the overall sensitivity to be ~ 87dB for this 4 ohm version of the SB17
