Built a delta-sigma DAC/Line Stage as shown below:
The DAC module is the "Buffalo IIISE-DAC", which is based on the ESS Sabre32 Reference (ES9018) DAC chip and accepts direct DSD, I2S and S/PDIF inputs supporting up to 32-bit/192kHz.
A liner power supply is used to feed a low noise regulator (SuperTeddyReg) that provides the 5.25 volts for the DAC module.
The volume control is done in the digital domain of the Buffalo IIISE via a linear potentiometer.
The output stage is a tube line stage called the "Unbalancer", which was designed by John Broskie:
All capacitors and resistors were upgraded. A separate tube rectifier power supply (Janus) is used to provide the B+ voltage and DC heater voltage for the line stage.
Duelund PIO 1uf / 630VDC, CAST-PIO-Cu Coupling Capacitors (I like these) are used:
DSD and PCM signals from a modified Denon 1920 multi-player are extracted from the player by tapping directly to the chip pins as shown and noted below:
Per the following pin connections:
DVD-1920 DSD -> Buffalo
BCK (Pin 37) -> DCK
DSD1 (Pin 38) -> D1
DSD2 (Pin 39) -> D2
G (Pad CS52) -> G
DVD-1920 PCM -> Buffalo
PBCK (Pin 50) -> DCK
PLRCK (Pin 51) -> D1
PDATA1 (Pin 46) -> D2
G (Pad CS52) -> G
And distributed to the DAC via an RJ45 cable:
I think it sounds great.
Next step is to build or buy a music server to play downloaded HD recordings into the DAC.
Cheers
Kris
BCK (Pin 37) -> DCK
DSD1 (Pin 38) -> D1
DSD2 (Pin 39) -> D2
G (Pad CS52) -> G
G (Pad CS52) -> G
Cheers
Kris
