For a while ive been gearing myself to building the modula xtreme so's since they fit my requirement perfectly. However maybe they are going to be a bit too extreme for me, if I'm looking at around $1600 at least for two speakers Im not sure i can justify it at the moment.
I'm looking at this kind of setup because I've built a subwoofer but it really needs more than just a mid range to tie things in together because the output of the subwoofer is so high and lacks the higher low end (if that makes sense). At the very least the system would need to have one woofer.
If i wasn't to go down the modula route, what other options might be available to me in a slightly cheaper package?
Any help would be appreciated so i can work out my options.
