Seas W15CY measured in box at 90DB/1meter with mic 4" from cone.
Accuton C79 measured in box at 90DB/1meter with mic 4" from cone.
Some of you may know that I am working a 3-way using the Aurasound NS10 driver, an Accuton C79, and Vifa D26 tweeter. I've been looking for a midrange that can outperform the C79 or possibly offer an alternative midrange bandpass section. However, the Accuton C79 seems to do things that no other stiff cone driver can do, such as maintain low odd order harmonics beyond 1.5k. Notice how low the 5th order harmonic distortion is in comparison to the W15CY.
The W15CY seems to be the champion below 200hz though, and it is very very close up to 1.5k. The question then becomes, what are my design goals and if I want to stick with the Vifa D26, will that really work with a W15CY?
I think the answer is no, since the Vifa D26 distortion really starts to rise below 2k.
That makes a very robust tweeter, like the Seas 27tdfc-g, an absolute mandate. The W15CY distortion profile suggests to me that a crossover of 1500-1700hz would be ideal.
The C79 should be crossed over ideally at 2k, since the 3rd harmonic distortion starts to get elevated by 3k, but it still isn't nearly as high as the W15CY 3rd order spike at nearly the same frequency. I would bet that the C79 can be used with a ribbon tweeter, such as the Fountek CD3.0 crossed around 3-3.5K. However, currently, I'm using the D26 with the C79 crossed at 2.25k and the sound is superb.
So, I just thought I would share some of my thoughts as I look more closely at these drivers. The W15CY looks very good indeed, just seems a bit more limiting as a midrange.
