Does anyone else have problems with a ground hum with a Halo amp? I didn't have it on my two channel system but when I swapped it into the HT system it appears. It is the loudest hum I have ever hear. I swapped amp positions with the ARC and the hum followed the A23. I tried replacing cables, re-routing cables, the ground lift switch. I didn't see a stud for attaching a case ground. The components are isolated on wood shelves.
A23 Hum
Originally posted by Pookie007Does anyone else have problems with a ground hum with a Halo amp? I didn't have it on my two channel system but when I swapped it into the HT system it appears. It is the loudest hum I have ever hear. I swapped amp positions with the ARC and the hum followed the A23. I tried replacing cables, re-routing cables, the ground lift switch. I didn't see a stud for attaching a case ground. The components are isolated on wood shelves.
If you don't have cable, then the other possible problem might be that you have your gear hooked up on different electrical circuits. Try unplugging the power cord of gear sitting on different circuits (video projector, powered subwoofers, etc.). If the equipment causing the problem is grounded, a $0.99 cheater plug from Lowe's hardware will probably solve the problem.
If you still can't find the problem, do it the other way around. Unhook everything. Start with amp+preamp only. Then hook up one unit at a time and test in between every moment. That will identify the source of the hum.
The ground switch on the Parasound amps is useless. It does not disconnect the chassis from ground as is implied. If the amp hums with nothing but the preamp connected, you should try a cheater plug on the amp.
Peter- Bottom
Originally posted by Pookie007The odd thing was I don't have any sort of hum with my Audio Research amps.
Peter- Bottom
I solved my hum with my sat rcvr by connecting speaker wire between the metal chassis of the amp and the sat box. Much cheaper than buying anything from Monster
-Mike- Bottom
I had the voltage regulator already. I just never needed to use the cable filter before. My initial plan was to ground the chassis together, but the Parasound didn't have a grounding nut and I didn't want to remove any of the other screws.- Bottom
Originally posted by mikepinkertonI solved my hum with my sat rcvr by connecting speaker wire between the metal chassis of the amp and the sat box. Much cheaper than buying anything from Monster
-Mike
Did you see any detoriation in the cable signal (check all channels) ? When doing simple grounding to solve the problem, you move the potental differences from your equipment to the cable wire...
A true isolator is the safest solution IMHO.
Peter- Bottom
I got a catalog from Sweetwater last week (pro recording gear) and they had a plug that they claim would cure ground-loop hum without defeating the ground (as all 2prong plugs do).
I can put up a link if you're curious. I still am satisfied with my speaker solution, tying the two grounds together. *shrug*
-Mike- Bottom
I am not sure how it did it, but the Monster Power HTS 3600 Power Center solved the hum problem. It has some sort of filtering shown on the mimic bus for coax connections.
My cable signal strength is fine. I have digital cable and all channels are working fine. I also ordered pay-per-view this weekend, so I have two way communication working also. There has been no problems at all. I was shocked at how hot the Halo amps run compared to the ARC.- Bottom
