Hey guys, I'm just getting into HT stuff but I always try to DIY in all of my hobbies. Looks like a good place to start in this one is a Sub. I've done a bit of lurking around and I just wanted to run my first little project by the rest of you.
Pretty simple really...I plan on using this driver:
With this amp:
And then building a down firing sealed enclosure per the Manufacturer's Specs.
Anybody see a problem with this?
One more thing, the total cost will probably be around $150. Will this DIY sub (assuming I build it properly) outperform a pre-made brand name sub in the same price range?
Thanks!
Adrien
With this amp:
Thanks!
Adrien
