Hey Jim. Long time no talk! You and Curt must be happy with your speaker selection lately as things seem to be quiet around SDW
I wanted to pick your brain. I want to pull my Bordeaux speakers off of the wall a bit. I remember reading that the crossover, stuffing in the tunnel etc are tuned for a certain distance off of the wall. I like the way they image being 24" off of the wall to the back of the bass cabinet. I believe the greater distance helps to separate the direct sound from the reflected sound which seems to give a deeper image and a better center image. I can accommodate up to 4' off of the front wall. I also get much tighter bass which is an added benifit.
What specifically would you change to accommodate this? Also, you mentioned stuffing the tunnels to taste. What specifically changes when you stuff it more and less? Less dense stuffing, more of a rear-firing wave?
Also, I wanted to note that I have had a lot of sources, amps, and speakers come and go. The Bordeaux still hold their ground and stick in my room like glue. As of now, I am powering them with all DIY equipment with a newly added Pass Labs XA25 clone. It is basically a XA25 but with higher bias so 70w of class A and some neat circuit tricks. Most dynamic and revealing amp that I have had to date. The amp is the reason for me to want to start to playing with positioning more.
For anyone interested, I found a neat few posts from Curt:
If you read through the thread, he made a few very interesting posts.
