I am considering purchasing the F208 for use as front-speakers in my home-theater; and have a few questions:
1.The speakers are about 46" tall. Would the drivers be able to present a coherent sound-image at a listening distance of about 10'6"?
2.Do the aluminium drivers have any hint of metallic "ringing" to them, especially in the midrange, affecting voices in particular?
3.I intend to bi-amp them and send ALL low-frequency signals (including the .1 LFE channel as I wont be using a subwoofer) to them. I was told they have strong bass capability so this would not be a problem. However, would a good AVR be sufficient? I own a Denon 2310 (UK-voiced, 105 x 7 RMS) but would I need to upgrade this to, say, a Cambridge Audio 751R with a toroidal transformer offering 120 x 7 RMS? In either case, channels 6 and 7 of the receiver would be configured to bi-amp the front speakers.
4.Last, I have heard conflicting reports about their overall sound: some say its "musical" while others say it lacks "refinement". Which is truer?
I'm hoping to audition these soon at a local dealer but auditions here are typically unreliable. Other speakers on my shortlist are B&W CM10 and the new Monitor Audio Silver 10.
Thanks in advance for any advice!
