I read in a few threads that some people said you can use a 1/8 3.5mm stereo jack instead of a mono, cable as a 12v trigger. Is this true or will I blow up my Krells as I haven't found a mono 3.5 cable yet here in France
12v trigger can I use a stereo cable 3.5mm 1/8
Tags: None
Originally posted by misterdoggyI read in a few threads that some people said you can use a 1/8 3.5mm stereo jack instead of a mono, cable as a 12v trigger. Is this true or will I blow up my Krells as I haven't found a mono 3.5 cable yet here in France
Peter- Bottom
Yeah, Its definitely 12v. Actually I am using the C1 with the Krells now as I have 2 cables. I bought 2 more stereo jacks as I couldn't find the mono for hooking up the rcd 1072 Rotel cd player which only shuts off with a 12v trigger.
post note: I tried a stereo jack and it works fine. I think its better to have it turn on and off with power than to "sense" the signal, because if you happen to flip thru sources for a moment you shut off the cd and have to start all over. Just having it come on and off with the system is fine.
Thanks again Peter
ps I used to date a Finnish Girl way back when......Last edited by misterdoggy; 20 June 2005, 07:57 Monday.- Bottom
I found that a 3.5mm stereo adapter to a 2.5mm jack will not work with the Parasound A51. It definitely requires a 3.5mm mono to 2.5mm mono connector.
This brings up another point which I don't understand. Why does Parasound use a 2.5mm trigger jack on the A51 but most pre/pros and receivers use the 3.5mm jack. Including Parasounds own C1 and C2. I don't get it. What's the reasoning behind that?Mitch
:stupidpc:- Bottom
Hey, good question. Never thought of it--and have no idea what the answer is.
Maybe it's like those air filters on Apollo 13--the LEM has round filters, the moon lander has square filters. (or was it the other way?)CHRIS
- Pleasantville- Bottom
I don't know but I had a heck of time trying to find an adapter. Rat Shack was clueless. Parasound is sending me one 2nd day air so I can finsih auditioning the A51.
Chris,
How are you turning on your A51? Manually? Audio Signal? I found the audio signal to be to finnicky. No matter what I set the adjustment knob to it either wouldn't turn it on reliably or it would shut off while I was watching Sat TV.Mitch
:stupidpc:- Bottom
Originally posted by mitch57I found that a 3.5mm stereo adapter to a 2.5mm jack will not work with the Parasound A51. It definitely requires a 3.5mm mono to 2.5mm mono connector.
Any kind of stereo-to-mono wiring is likely to fail, because these adaptors sometimes short the left+right. This does not work. If a stereo plug is used, the left channel is positive trigger [+] and the right channel will be the same as the common, i.e. negative trigger [-]. If left and right are shortened by the adapter, you have a problem :B
Originally posted by mitch57This brings up another point which I don't understand. Why does Parasound use a 2.5mm trigger jack on the A51 but most pre/pros and receivers use the 3.5mm jack. Including Parasounds own C1 and C2. I don't get it. What's the reasoning behind that?
Peter- Bottom
Originally posted by Peter NielsenA 3.5mm stereo <=> 2.5mm stereo adaptor WILL work. If you run stereo ALL the way, there will be no problem. Combining stereo and mono converters/cables may lead to problems:Mitch
:stupidpc:- Bottom
Mitch, I've got the A21 daisy-chained to the A21 that goes to the autotrigger. It works absolutely fine--I've never had a single problem with it. Both turn on when I turn on the C1, and shut off when I shut it off.CHRIS
Originally posted by Chris DMitch, I've got the A21 daisy-chained to the A21 that goes to the autotrigger. It works absolutely fine--I've never had a single problem with it. Both turn on when I turn on the C1, and shut off when I shut it off.
Do I have that correct? I'm just trying to gage if anyone is using the auto signal sensing feature and having it work consistently and reliably.Last edited by Chris D; 26 May 2016, 22:00 Thursday.Mitch
:stupidpc:- Bottom
Whoops... you're right, I had a couple typos. Using your sentence again,
I'm using the 9-12V DC trigger from the C1 to the trigger IN on my A51 which has a trigger OUT wire going to the trigger IN wire on my A21.CHRIS
How much do I win for digging up a ten year old thread?
I was actually googling 12v trigger stereo vs mono and found this thread. I know it's the Parasound club but I've got a Denon 2307CI -> Emotiva XPA-5 amp and it's strange, everywhere I look people say use 1/8" mono -> 1/8" mono. That doesn't work for me but stereo does. So the question is, what is going on here? Are all the brands different or something? I mean it's a simple voltage on/off so it seems like it shouldn't matter.-Chuck- Bottom
No offense to Roy Rogers, but I hate triggers! LOL.
I have always somehow got by and made this work Chuck, but I am not sure what to tell you here. Watch out, sometimes Kevin whacks people that dig up old threads, lol. JK.Doug
"I'm out there Jerry, and I'm loving every minute of it!" - Kramer- Bottom
I was actually googling 12v trigger stereo vs mono and found this thread. I know it's the Parasound club but I've got a Denon 2307CI -> Emotiva XPA-5 amp and it's strange, everywhere I look people say use 1/8" mono -> 1/8" mono. That doesn't work for me but stereo does. So the question is, what is going on here? Are all the brands different or something? I mean it's a simple voltage on/off so it seems like it shouldn't matter.- Bottom
Ah, I wonder if Denon did that as well. Though mine does have two separate trigger ports. It could be the Emotiva too, I'm not sure which. All I know is mono doesn't work and stereo does, just thought it was strange. That kinda implies that it's *only* using the middle part of the connector.-Chuck- Bottom
I guess it depends on whether the company uses a mono or stereo jack for their trigger outputs, and how they wire them up.
Hmmm... <clicky> admin control panel <clicky> impala454 <clicky> move to spammer group <clicky> wait a sec, how'd he get 3,794 posts? <clicky> Wait, he's an ultra senior? Maybe not a spammer? <clicky> well, dodged a bullet there. haha J/K.
Actually when I clicked this thread and saw posts from 2005, I went to the end just to see *who* did bump it back up. Sometimes spammers do just that, because they're idiots. They think they'll slip under the radar, but in reality it just makes them easier to spot.- Bottom
