This is a very limited and focused "Design Study", principally investigating the feasibility of using a planar midrange in an existing proposed system design, and determining what system parameters may be necessary to "extract" acceptable results from what is not a simple driver to work with.
This is the published response data for the driver under investigation, the GRS PT5010.
In the manufacturer data sheet, many standard specification items are listed as N/A, even when as detailed examination of other data indicates relatively simple derivation.
This is an impedance curve measured on the first test sample...
This effort has involved developing a driver model and investigating theoretical efforts to produce more satisfactory results in a system build than the data sheet hints at. Due to the mandates of SMJ Imperial management, the details are considered proprietary at this time, though that status may change in the future.
This is an interim report, as another update to the test configuration is already in preparation. But the initial results from the first pass exhibit some useful and encouraging characteristics worth discussing in passing...
The impedance curve in the test configuration...
And the measured response...
It might be worthwhile to note that the measured HD3 at this level of output was at ~-70dB from 700Hz to 5kHz. A most satisfactory result. No electrical networks are involved at this point.
Further suppositions have been made from this first test configuration, and a second one is in construction which if insights are correct, should further improve the results.
