I am using some C-Coil inductors from Jantzen for my Modula TMM build. Them, along with every other inductor and part get measured prior to using them in my crossover. Every other inductor i have measured in the past ends up being ever so slightly above the stated inductance, which is great because then i can just unwind a wrap or so and home in on the value i need, but in the end measure up precisely. However, when i measured these C-Coil inductors, they can in well (like ~70% of) below the stated inductance. For example, below show my measurements on the 1.5 mH and 3.3 mH c-coil inductors:
This seems too large to be typical tolerances; 1.5 mH with a 10% tolerance would yield no less than 1.35 mH. Shows is 29% of nominal value too low!! Whats is odd is that 1.07 is 71.3% of the nominal value, and 2.35 is 71.2% of nominal, it's almost like its something I'm not accounting for. There isn't some weird principle of steel core, or toroidal steel core inductors that I am not aware of is there?
I originally got a 3.3 mH to unwind down to the required 3.0 mH, but with this, i don't even know what to do. I have just installed them as is into my XO, but I am debating returning them and getting a different 14 AWG steel core, one that mey measure more accurately. I know Jon Marsh has used these in his designs, and many others have built the Modulas, so anyone else measure their c-cores and get something really off?
Thanks!
Thanks!
