Which end is postive on capacitor???
  • CADman_ks
    • Jan 2012
    • 497
    I have these capacitors in my crossover:
    I now have them built, and I'm wondering if I have them going the correct direction.
    Is there a "+" and "-" to this style of cap?
    CADman_ks
    CADman_ks
    - Stentorian build...
    - Ochocinco build...
    - BT speaker / sub build...
    • 5568
    You should be using NP caps, which do not have a + or -
    If they do have polarity, they're marked rather clearly.
    • Kevin P
      • 10808
      Polypropylene capacitors are non-polarized. You can use it in either direction.
        • 15282
        CADman_ks
        Those are metallized film polypropylene capacitors- they do not have polarity, and you can connect them interchangeably. Electrolytic caps come in two versions; most are polarized, but NP types exist which are actually two polarized caps connected back to back. Not really a very nice way to make capacitors.
        • CADman_ks
          • Jan 2012
          • 497
          Thanks!!!
          Thanks to all, and this is good information for others that may have the same question.
          I thought that was the case, but I was just checking to make sure.
          CADman_ks
          CADman_ks
          • Boulderjl
            • Feb 2021
            CADman_ks
            For sure, I was just freaking out that my built and installed crossovers had the polarity incorrect. I havnt cpompleted the speakers yet. Came across this post and now I can relax. Thanks
            • CADman_ks
              • Jan 2012
              • 497
              LOL. I'm glad that this was helpful for you!
              Make no bones about it, I'm no spark and wires guy, well, I'm a sparks guy, typically when I have it wrong!!! I absolutely know just enough to be dangerous with electricity!!!
              Have a great day!!
              CADman_ks
