HT build: Statements II L/R, Statements II C, Finalist Surrounds and Rythmik F15hp x2
  • BiKESEAT
    • Nov 2010
    • 23
    11 years ago I built the overnight sensations while living in the UK, they were appropriate for budget and space. In 2015 we moved back home to Australia, so in early 2015 I bought all the parts for this build. Since then I've built a house (as a owner builder), had our second child and now it's finally time to build my speakers after having all the parts on the shelf for 6 years.
    I've had some experience with CNC and mach3, and wanted to do rebated edges so everything self jigs. So I bought a 1.5m x 1.5m queen bee kit last year and build it at the start of the year.
    Work and other commitments then got in the way, so I finally started the actual speakers build a few weeks ago. Took me a little while to sort out gremlins in the machine, but running nicely now.
    First up, sub parts
    Then moving on to the 4 x finalist parts and centre channel ...
    Test fitting drivers... parts are so old I've still got the RS28f..
    Sub gluing
    First Sub done, minus roundovers. There's hidden magnets for a grill if the Mrs wants it.
    So that's where I'm at. Hoping to get the second sub and centre glued up tomorrow.
    The sub's I'll have sprayed in 2 pac satin black, the 7 x speakers done in American red oak with a darkish stain, similar to the ATMOS speakers I did awhile ago but a bit darker.
    Last edited by theSven; 06 April 2023, 17:34 Thursday. Reason: Update image location
  • Scareurpasenger
    • Jan 2017
    • 68
    How is that cnc machine? The price seems pretty reasonable.
    • BiKESEAT
      • Nov 2010
      • 23
      It's surprisingly good. Accurate to around 0.1mm, the only issue is the depth control, I need to sort out a better base and spoiler board arrangement. It's made some of my 2mm rebates a bit of an issue when they vary up to 0.5mm.
      Overall it's exceeded my expectations.
      • CADman_ks
        • Jan 2012
        • 497
        I've had some experience with cnc and mach3, and wanted to do rebated edges so everything self jigs. So I bought a 1.5m x 1.5m queenbee kit last year and build it at the start of the year.
        I don't want to hijack this thread, but that Queen Bee is the BOMB, and that is a very reasonable machine for sure.
        How did you decide on a controller, though? I have a TON of CAD experience, and can create all the GCODE files that could ever be needed, but that doesn't mean that I know anything about actually controlling a machine like this. It appears that you did not go with the recommended controller option from QueenBee. Just curious what drove you to a different controller.
        Speakers, and parts look GREAT!!!
        CADman_ks
        - Stentorian build...
        - Ochocinco build...
        - BT speaker / sub build...
          • 1890
          Very cool on all fronts .... speakers, CNC and house building.
          • BiKESEAT
            • Nov 2010
            • 23
            The controller is an option from here
            QueenBee PRO Bulk-Man 3D is the largest wholesaler of Open Source CNC parts to the world. By having the parts produced ourselves, or sourcing the parts directly from the factory, we eliminate the m…
            If I bought again I'd got with an ethernet one, not USB. This one has a few little quirks around homing etc, but once I had the machine grounding sorted out it's been reliable.
            I'd also build the electronics in a metal box so I didn't have to ground all the connectors independently.
            • CADman_ks
              • Jan 2012
              • 497
              Thanks for the reply!
              Which one did you end up with? When I look at the options that they have, it appears that they only have one that has ethernet connectivity, and that's thru WIFI, and that's the recommended solution, the CNC xPRO V5. It's also the most expensive, by about another 1/3, but I know for me, I need simple over powerful when it comes to stuff like this. If I have to monkey around with it a lot, I'm probably going to lose interest pretty quickly. I just want tools to work...
              CADman_ks
              • BiKESEAT
                • Nov 2010
                • 23
                I went with the UC300 which is USB. However it still has been ok once I fixed the grounding.
                • BiKESEAT
                  • Nov 2010
                  • 23
                  Bit more progress, second sub done
                  Surround baffles and test fitting
                  Working on centre...
                  Centre finished, well glued and foamed at least.
                  Last edited by theSven; 06 April 2023, 17:36 Thursday. Reason: Update image location
                    • 3223
                    Sweet! :T
                    • BiKESEAT
                      • Nov 2010
                      • 23
                      Thanks Jim!
                      So the subs, centre and 4 x finalist surrounds are glued. Will do the mains in the next week / two, then a side project of the RS225 and RS28f (mark K's) 2 way for the workshop after that.
                      Then on to finishing and building crossovers.
                      • BiKESEAT
                        • Nov 2010
                        • 23
                        Long time since an update, I've finished the fronts, center and the two subs painted. Happy with how the finishing turned out.
                        They sound amazing, even with my very sub optimal room placement. They have a big room gain on the low end when looking at the measurements from REW, but I kind of like that. Unfortunately due to the fireplace column in the middle of the room the imaging isn't quite perfect, but the detail is magnificent so I'll take that.
                        They're being driven with rotel RB1572 for fronts (2 x 500w), 1575 for centre and surround( 5 x 500w). Denon 3700h receiver.
ID:	866317Click image for larger version
ID:	866318Click image for larger version
ID:	866319Click image for larger version
ID:	866320Click image for larger version
ID:	866321Click image for larger version
                        • BiKESEAT
                          • Nov 2010
                          • 23
                          Just doing the top coats on the surrounds now, then will try and drag them all together for a completion photo.
ID:	866322Click image for larger version
ID:	866323Click image for larger version
                            • 3223
                            Very, very pretty! Nice job!
                            • YouTubeUniversi
                              • Aug 2021
                              • 17
                              Dang, finalists for surrounds? I was thinking of overnight sensations personally. Why not just make full size statement surrounds? Lol when in Rome
                                Very crisp construction, what kind veneer did you apply?
                                • BiKESEAT
                                  • Nov 2010
                                  • 23
                                  American red oak, paper backed. I had to import it from the US as there aren't any paper backed veneer suppliers here in Australia. Stained with general finishes nutmeg gel stain.
                                    Master of None
                                    • Jan 2014
                                    • 1058
                                    Very nice build job! The veneer looks fantastic with how that is turning out.
                                    Painter in training
                                    • BiKESEAT
                                      • Nov 2010
                                      • 23
                                      Thanks for all the comments guys.
                                      They're all finished now. Turned out to be a big project. I need to make some better stands for the surrounds, will match the style of the statements bases. I'm away for 2 months for work now, so will be likely in the new year.
                                      Click image for larger version  Name:	20211022_120815.jpg Views:	1 Size:	152.0 KB ID:	866325Click image for larger version  Name:	20211022_120824.jpg Views:	1 Size:	151.1 KB ID:	866326
                                      Last edited by theSven; 06 April 2023, 17:40 Thursday. Reason: Update image location
                                      • BiKESEAT
                                        • Nov 2010
                                        • 23
                                        Size comparison to the overnight sensations I did 10 years ago.
                                          • 3223
                                          Wow! Awesome build!
                                          • BiKESEAT
                                            • Nov 2010
                                            • 23
                                            Thanks Jim! Thank you very much for the designs!
                                            • 1Michael
                                              • 293
                                              Two thumbs up smilies ...
                                              Michael
                                              Chesapeake Va.
                                                • 1890
                                                Very Nice .....
                                                  Master of None
                                                  • Jan 2014
                                                  • 1058
                                                  Nothing but WOW!! I hope you get to spend some serious time enjoying them when you get back from your work trip.
                                                  Painter in training
