Inam embarking intona new world for me. I would like to ask you folks a few questions before I start buying the materials and speakers for the statements build. If you have the time to provide your feedback to these questions, I would greatly appreciate it.*
1. I mostly use my speakers for home theater, so I am trying to upgrade my towers from the existing polk rti 10s I currently have. Since I cannot hear the statements, I have to ask a silly question. Would these statements sound significantly better than the polls? I assume they will simply due to the better quality drivers, but I want to be sure.
2. These statements use a ribbon tweeter, and my center does not. My center is a MTM I bought from parts express which has a standard tweeter. Can I mix these or can I simply replace the tweeter in my center to match the towers?
3. If the answer to number 2 is no, and I would have to replace the center, is there a center to match the towers?*
4. The link to the statements is quite old, is there a newer DIY setup that is a better solution or are the statements still the best option?
Thanks in advance. I really appreciate you taking the time to read and respond. Much appreciated.
