Double curved Statement II and Statement II Centre
  • SaltyPaws
    • Jan 2015
    • 22
    With all the buzz around the Statements, I have to get myself a pair! The main complaint around the statements seems to be WAF, so my mission is to tackle that downside. I am planning to solve this, by adding curves to the statement. While this has been done before, I don't know of any build using my methods (3D CAD, 2D CAD, CNC). I have spent the last year gathering information, and finishing the design. Now the time has come for dust to fly freely!.
    The tools I am using:
    Design calculations: Libre Office
    3D CAD: Blender
    2D CAD: LibreCad
    I am posting some CAD screenshots to kick off the post:
    Design Iteration #1, Finalists with different dome curve. I liked the front to back curve
ID:	872055Click image for larger version
ID:	872054Click image for larger version
ID:	872053Click image for larger version
ID:	872056Click image for larger version
  • SaltyPaws
    • Jan 2015
    • 22
    Iteration #2 Finalists internals
    Design Iteration #2, drawing the curved finalists with internals.
ID:	862197Click image for larger version
ID:	862198Click image for larger version
ID:	862199Click image for larger version
ID:	862200Click image for larger version
    • SaltyPaws
      • Jan 2015
      • 22
      Iteration #3 WTMTW statement II
      And this is iteration number III
      at this point I decided I wanted to go with the statements, curved side and curved dome. I really like the ribbon tweeter for some reason...
Name:	Screenshot from 2015-07-06 03:12:01.jpg
ID:	862202Click image for larger version
Name:	Screenshot from 2015-05-01 11:12:05.png
ID:	862203Click image for larger version
Name:	Screenshot from 2015-05-07 11:53:02.png
ID:	862204Click image for larger version
Name:	Screenshot from 2015-05-07 11:53:17.png
ID:	862205Click image for larger version
Name:	Screenshot from 2015-05-07 11:53:37.png
      • SaltyPaws
        • Jan 2015
        • 22
        Iteration IV - Truncated statements
        At this point, I decided that I wanted to go for truncated statements to reduce the height, and increase the WAF. According to Deewan, his truncated statements worked out great:
        Some of the pictures no longer display because Photobucket discontinued their free picture hosting service. SORRY! Hey guys. It's been a while since I've been an active poster to the boards because I haven't been building many speakers in the past few years. That drought has come to an end. The past three builds I have done
        Deewan is a fantastic finisher, unlike myself.
        The best compliment I have had however, is someone who asked where I had my subwoofer done with leather... It is hand painted
        You might have gathered that I am an engineer. I will not build the speakers, without a decent plan, drawings and the calculations to back it up!
        Iteration IV:
        Click image for larger version  Name:	Screenshot from 2015-05-07 11:56:18.png Views:	1 Size:	15.8 KB ID:	862207Click image for larger version  Name:	Screenshot from 2015-05-07 11:56:48.png Views:	1 Size:	15.6 KB ID:	862208Click image for larger version  Name:	Screenshot from 2016-08-14 15-47-50.jpg Views:	1 Size:	64.8 KB ID:	862209Click image for larger version  Name:	Screenshot from 2016-08-14 15-49-13.jpg Views:	1 Size:	85.7 KB ID:	862210Click image for larger version  Name:	Screenshot from 2016-08-14 15-49-42.jpg Views:	1 Size:	86.0 KB ID:	862211
        • SaltyPaws
          • Jan 2015
          • 22
          Centre design
          And with the curved statements do go the curved centre speakers.
Name:	Screenshot from 2016-08-14 15-54-15.jpg
ID:	862212Click image for larger version
Name:	Screenshot from 2016-08-14 15-54-31.jpg
ID:	862213Click image for larger version
Name:	Screenshot from 2016-08-14 15-54-43.jpg
ID:	862214Click image for larger version
Name:	Screenshot from 2016-08-14 15-55-17.jpg
ID:	862215Click image for larger version
Name:	Screenshot from 2016-08-14 15-55-41.jpg
            • 3223
            Looks great!
            • WLDock
              • Jun 2013
              • 22
              Looking good!
                • 1670
                This is looking really cool.
                Not sure if you just want to share where you are in the process, or if you want more input and ideas as well.
                Throwing in some more input as well - but that does not mean that I think you need it. Your current design is looking really cool!
                In additon to what you already have done, you could break up the look even more by doing something like what Sonus faber have done here:
                An option I do not see in your first iteration design choice is having the top bowing the other way around, inspired by this design:
                Looking forward to following this build!
                Last edited by theSven; 30 April 2023, 14:33 Sunday. Reason: Update image location
                • SaltyPaws
                  • Jan 2015
                  • 22
                  Liner
                  The design phase is over, and the parts have been cut. I will post some pictures of the process soon. In the mean time, I am thinking about the lining and the stuffing. This is what I am planning to use as liner for mid and woofer chambers:
                  Do you think this would work?
                  And planning to use stuffing for woofer (inter connection), mid chambers (as directed by Jim roughly 1/2 of mid chamber). Jim indicated that stuffing for the woofers is optional, how much should I use in the woofer section?
                    • 3223
                    Hi Salty,
                    Make sure you can blow through the mattress foam which would indicate it's open cell foam and can be used for acoustic purposes. Closed cell foam will not work in speakers. The woofer and mid compartments should both be lined with foam everywhere you can see when looking through the driver cut out hole. I also included a 2-3 handfuls of fiber fill in the back 1/2 of the mid compartment. You can do the same in the woofer compartments too if you wish. Just be sure the fiber fill doesn't crowd or get into the back of the driver. It' needs to "breathe" freely.
                    HTH
                    • SaltyPaws
                      • Jan 2015
                      • 22
                      MDF dust Aflying
                      Cutting the parts out on my CNC
                      • SaltyPaws
                        • Jan 2015
                        • 22
                        Test fitting
                        Test fitting (no glue jet)
                        • SaltyPaws
                          • Jan 2015
                          • 22
                          Thanks! I used the same material for my subwoofer. I tried on the left-over material, and I could blow trough it without a problem.
                          • jwanck11
                            • Jan 2016
                            • 115
                            This looks like an awesome project!
                            2 things:
                            Do the screws for the woofers have something to bite into on the outer ends?
                            Did you round over the back of the baffle for the woofers and mids?
                            • kevinm
                              • Jun 2013
                              • 417
                              Excited for this project. I love CNC builds
                              • SaltyPaws
                                • Jan 2015
                                • 22
                                Build Progress
                                Test fitting the cones and speakon connector.
                                Gluing the front inner and outer baffles (notice the nice dadoes)
                                Scalloping the mid and woofer (3/4 inch roundover and 1/2 inch V) - Hope this answers your questions
ID:	862294Click image for larger version
ID:	862293Click image for larger version
ID:	862292Click image for larger version
ID:	862291Click image for larger version
                                • SaltyPaws
                                  • Jan 2015
                                  • 22
                                  The Dome cap, hollowed out inside is now visible
                                  Gluing in the mid sides, with easy dado positioning
                                  All of the edges sealed with bondo, to ensure there is no leakage between mid, side and outside.
ID:	862295Click image for larger version
ID:	862296Click image for larger version
ID:	862297Click image for larger version
ID:	862298Click image for larger version
                                  • SaltyPaws
                                    • Jan 2015
                                    • 22
                                    The inside is now painted with left over paint from other projects. Maybe overkill, but I like to paint the inside of all my speakers.
                                    I am using titebond III for the curved sides, mainly because the longer opening times (titebond extend is hard to obtain here). Titebond is having a good customer in me, as I am using 6 oz per panel. Yes, I decided to go for the gallon! :T
                                    I am using bags of sand to press the curved sides on. From here on the operation is a little like Intels tick and toc. One day I use my clamps for pre-bending a plywood side, the next day the clamps are in use for the gluing. With 5-6 panels per side this is an arduous process... I will be putting the 3rd panel in tonight.
ID:	862300Click image for larger version
ID:	862301Click image for larger version
ID:	862302Click image for larger version
                                    • deewan
                                      • Feb 2009
                                      • 284
                                      I don't log on to this site much anymore since I am not currently building anything but thought I'd check in to see if there were any cool builds. I saw this thread title and figured I'd check it out. All of a sudden I realized some of the cabinet designs shown at the beginning looked a lot like what I built and I was prepared to offer some advice from my experience. Then I saw the CAD drawings and CNC machine. That's cheating!!! If you aren't hand drawing blueprints and hand cutting mdf, it's just not fair.
                                      But seriously, great looking build so far. Keep up the great work and I will be checking in more often to see the progress of these beauties!!!!
                                      The Old Woods Theater
                                      My Various Speaker Builds
                                      Statement II Remix build
                                      • SaltyPaws
                                        • Jan 2015
                                        • 22
                                        @Deewan, I don't think using a CNC is cheating. When taking into account all the time I spent making the drawings, and getting to know the CNC machine, I would have been much quicker doing everything by hand. However, cranking out the next set will be easy ;-)
                                        I still would like some of your advice. I need to trim off all the edges. Since the sides are curved, I am not sure how to do this with a router. Any advice on how to best do this? Thanks!!
                                          • 1670
                                          Very nice build!
                                          To trim your sides I think you might have to build some kind of jig for your router so that it follows the edge.
                                          But I guess some others here will give some more tested advice...
                                          What do you plan for finish and preparation?
                                          • DocNice
                                            • Aug 2016
                                            • 32
                                            That is badass! And I'm just slightly jealous of your tools :-)
                                            • flamethrower1
                                              • 392
                                              Nice work, those are going to look very nice.
                                              Good luck with the progress
                                                • 1670
                                                How thd this go? Did you complete them?
                                                • WLDock
                                                  • Jun 2013
                                                  • 22
                                                  I'd like to know as well. I'd love to build some curved versions and have it CNC cut. I just don't have the skill to do the CAD or know someone local with a CNC. It would be too pricey to have someone mock things up and perform the cuts. So, I may not get the chance, DIY all the way.
                                                  • Ante
                                                    • Dec 2016
                                                    • 67
                                                    Hi I am alsow very interested in this project. I might build a sett of curved statements my selfe. I have axses to a cnc mascine and it would be pretty cool to try out your design if you would let me Hope we can gett some feedback on this
                                                    • Renron
                                                      • 750
                                                      SaltyPaws,
                                                      Any update you could share with us?
                                                      Ron
                                                      Ardent TS
                                                      • SaltyPaws
                                                        • Jan 2015
                                                        • 22
                                                        Sides are glued on
ID:	862857Click image for larger version
                                                        • SaltyPaws
                                                          • Jan 2015
                                                          • 22
                                                          Trimming the edges straight
ID:	862859Click image for larger version
                                                          • SaltyPaws
                                                            • Jan 2015
                                                            • 22
                                                            Almost ready for paint
                                                            Almost there! I finished the X-overs and did the difficult roundovers (non 90 degree angle means manual corner roundoff). I ran out of tape to protect the front baffle from the roundover bearing.
                                                            I Placed Bondo on the soft cnced mdf
                                                            I also used bondo for the hardboard to baffle transition. I will post some more pictures soon.
                                                              • 5673
                                                              your curved 'top-hat' is truly rare in a DIY cabinet.
                                                              really impressive work.
                                                              • SaltyPaws
        • Jan 2015
        • 22
        Rounded over corners and smooth domes
        • DigitalMaven
        • Feb 2017
        • 36
        Salty paws...is there a reason for orienting the ribbon tweeter sideways instead of vertical. the lengthy way ensures a tighter side to side window with a greater vertical dispersion. Also, I would look into madisound or parts express for open cell acoustic foam. I use madisounds natural wool stuffing and a lb bag should be more than enough for your speakers. Just make sure that you leave enough space behind your midrange drivers so that you don't muck up the midrange frequencies.
        • 5673
        gzubeck (DigitalMaven)
        maybe you are referring to the Center speaker enclosure?
        speaking of which, my previous statement regarding the curved 'top hat' would also apply to the Center channel 'end caps'.
        • SaltyPaws
        • Jan 2015
        • 22
        It is a centre speaker... Orientation: horizontal on top of my subwoofer. This will orient the ribbon tweeter in the correct position. I already put foam lining in, before starting the second wall. I have a bag of stuffing for the woofers that will go in after as per advice from Jim.
        • DigitalMaven
        • Feb 2017
        • 36
        I went back threw the thread and I can see it now...makes sense now....
        • SaltyPaws
        • Jan 2015
        • 22
        Centre is Finished!
        I finally got to do my victory dance, as the centre speaker is finished! Some rain over the last weekend did help me in getting the box wired, and the cones and X-overs installed. First listening impressions: I can hear voices much better, even with background noise, something I struggled with on the old tv speakers. Breaking glass sounds like glass, bass really pops. The frequency sweeps sound good. I start to get good bass at around 50 Hz (With the sub on during the sweep, the sound starts at 20HZ +0db at (amplifier turned up to 25%) Needless to say cutlery rattles in the cupboard. In case I wasn't sure about the subwoofer being on, all I need to do is test the wall for vibrations :twisted.
        On to building the left and right now...
        • 3223
        Excellent! :T
        • SaltyPaws
        • Jan 2015
        • 22
        Some misc build pictures
        I never got around to posting these...
