Dave's 8" woofer + 104mm tweeter speaker build.
  • DaveFred
    • Sep 2018
    • 172
    ​I am a little late in starting on my InDIYana 2023 build, I spent quite a bit of time testing drivers to see which ones would work best for what I wanted to do. For those who do not know, the Midwest Audio Club has an annual get together in Fort Wayne Indiana in April where one of the things they do is have a friendly theme speaker contest. This years is, Mix a =>8" driver to a tweeter <=104mm inna box <=1.5 cubic feet. My entry will be a Wavecor WF223BD01 8.75" woofer, Seas Prestige 27TBCD/GB-DXT tweeter and Dayton 10" passive radiator in about a 1.3 cubic foot box, about 21" tall, 15" deep and 12" wide.
    Enclosure front/back/top/bottom will a pseudo translam with me making translam panels then butt joining them with a lock rebate joint. The baffle itself will start out as a 3" thick panel, but more than half by weight will be removed from it by the time the enclosure is done. Top/bottom/back will be ~1.125" thick panels with the sides being regular 3/4" baltic birch panels with ~1/4" cherry thick veneer applied to them.
    BTW, I am soliciting name suggestions for this build, so please suggest some!
    Click image for larger version  Name:	1 - Drivers.jpg Views:	1 Size:	252.1 KB ID:	929626
    Click image for larger version  Name:	2 - layout enclosure sketch.jpg Views:	1 Size:	213.4 KB ID:	929625
    Click image for larger version  Name:	3 - check size in real life.jpg Views:	1 Size:	266.9 KB ID:	929627
    Click image for larger version  Name:	4 - start with 2 sheets 5 x 5 3-4 BB.jpg Views:	1 Size:	337.6 KB ID:	929630
    Click image for larger version  Name:	5 - a whole pile of little bits.jpg Views:	1 Size:	329.3 KB ID:	929629
    Click image for larger version  Name:	6 - glueup begins.jpg Views:	1 Size:	308.5 KB ID:	929628
    Click image for larger version  Name:	7 - glueup begins 2.jpg Views:	1 Size:	415.1 KB ID:	929633
    Click image for larger version  Name:	8 - tops and bottoms in clamps.jpg Views:	1 Size:	380.7 KB ID:	929634
    Click image for larger version  Name:	9 - gluing many stips at once.jpg Views:	1 Size:	250.1 KB ID:	929631
    Click image for larger version  Name:	10 - baffles in clamps.jpg Views:	1 Size:	320.4 KB ID:	929632
  • DaveFred
    • Sep 2018
    • 172
    ... more pics ...
Name:	11 - all laminations done.jpg
Name:	12 - sanding laminations.jpg
Name:	13 - laminations sanded.jpg
Name:	14 - gonna kinda look like this.jpg
    • 1Michael
      • 293
      Sea of Waves😆
      Michael
      Chesapeake Va.
      • tktran
        • 658
        the Sea Waves
          • 15259
          Great stuff! I love it when the sawdust starts to fly!
          • DaveFred
            • Sep 2018
            • 172
            Doesn't sound like much when you say it, but took a fair amount of time, cut out the driver openings in the baffle and fastened T-nuts on the back of the baffle for fasteners to hold the drivers in,
Name:	15 - laying out baffle.jpg
Name:	16 - cutting tweeter rebate.jpg
Name:	17 - boring tweeter through hole 1.jpg
Name:	18 - boring tweeter through hole 2.jpg
Name:	19 - cutting tweeter wire ears.jpg
Name:	20 - collet extension not my favourite thing.jpg
Name:	21 - tweeter back rebate for clearance.jpg
Name:	22 - tweeter back rebate done.jpg
Name:	23 - nice tweeter fit.jpg
Name:	24 - clown calipers.jpg
            • DaveFred
              • Sep 2018
              • 172
              .. moar pics...
Name:	25 - as far as router bit would cut.jpg
Name:	26 - finish cut with jig saw.jpg
Name:	27 - woofer through cut done.jpg
Name:	28 - flush trim jig saw cut to circle cut.jpg
Name:	29 - nice woofer fit.jpg
Name:	30 - might need some back bevel.jpg
Name:	31 - starting back chamfer.jpg
Name:	32 - higher and higher cuts.jpg
Name:	33 - back chamfer steps.jpg
Name:	34 - cleaning up back chamfer steps.jpg
              • DaveFred
                • Sep 2018
                • 172
                . and more....
Name:	35 - very open back of driver.jpg
Name:	36 - lots of room to breathe.jpg
Name:	37 - bore flat bottom holes.jpg
Name:	38 - marking tweeter holes.jpg
Name:	39 - marking woofer holes.jpg
Name:	40 - drilling driver holes.jpg
Name:	41 - drilling flat holes.jpg
Name:	42 - flat holes drilled.jpg
Name:	43 - inserts inserted.jpg
                  Master of None
                  • Jan 2014
                  • 855
                  Excellent share of all the pics for this build!
                  I'm trying to think of a creative name... I like the first 2, so I will just throw this one out there... Bamboo Tsunami
                  Painter in training
                  • DaveFred
                    • Sep 2018
                    • 172
                    Here is a little work on the cherry veneered side panels for my InDIYana 2023 project, one side gets a Dayton DSA270-PR passive radiator and the other remains plain.
                    I knew I had been hanging onto some really gnarly cherry boards that were bought as part of a lot at an auction many years ago, and this was a good time to use them up as thick veneer for the sides of the translam enclosure.
                    Dressed them and mostly resawed them with a 3/32" Freud rip blade, finished on the bandsaw. Book matched panels were glued up and surfaced on a drum sander.
                    I don't have a vacuum press setup, so I made a torsion box and a platen to cold press the thick veneer onto the 3/4" Baltic birch sides.
                    For ease of travel, I wanted the surround of the passive radiator to be beneath the surface of the panel, so I added a second thickness of 1/2" Baltic birch to the back of the sides to allow for a deeper rebate. Rebate was cut in with 30º bevel sign making bit.
Name:	44 - firewood 1.jpg
Name:	45 - firewood 2.jpg
Name:	46 - cherry jointed and planed.jpg
Name:	47 - start resaw on table saw.jpg
Name:	48 - finish resaw on bandsaw.jpg
Name:	49 - pretty book matched panels.jpg
Name:	50 - glueup cherry sides.jpg
Name:	51 - sand panels.jpg
Name:	52 - coldpress 1.jpg
Name:	53 - coldpress 2.jpg
                    • DaveFred
                      • Sep 2018
                      • 172
                      More pics ...
Name:	54 - size thick veneer.jpg
Name:	55 - coldpress thick veneer onto ply.jpg
Name:	56 - flushtrim veneer to ply.jpg
Name:	57 - panels veneered.jpg
Name:	58 - making sides thicker for PR recess.jpg
Name:	59 - sign making bit with added bearing.jpg
Name:	60 - PR rebate.jpg
Name:	61 - PR inset in side panel.jpg
Name:	62 - mock up of side panel in place.jpg
                        • 15259
                        Now, that's Righteous! I thought I was weird for buying a lot of "interesting" solid woods and having a bit of a collection in storage- you're doing well with that, congrats!
                        Now, that's hard core- hard core cherry!
                        And to think some of my friends think my wood working stuff is hard core... Hah! I'm just a wires and sparks kind of buy,
                        basically!
                        So, how long were you hanging on to those cherry slabs?
                          • 998
                          Beautiful work. Really like how you carved out all that space behind the woofer. I should get a set of those bits sometime.
                          • DaveFred
                            • Sep 2018
                            • 172
                            When I came across the group of boards at the auction, I saw a nice hall table in one of them, but had to buy the whole lot.
                            Here is that table,
                            Click image for larger version  Name:	Cherry Table.jpg Views:	11 Size:	241.9 KB ID:	930737
                            (no baseboards on here yet)
                            BTW, the auction was in 2003.
                              theSven commented
                              Editing a comment
                              2 decades... Sometimes it just takes time for the pieces to fall into place.
                          • mordikai
                            • 8
                            sweet build Dave!
                            • DaveFred
                              • Sep 2018
                              • 172
                              Since my last installment,
                              Lock rebates were used for the top, bottom and braces to the baffle and rear of the speaker, makes locating things easier during glue up. Tongue is cut with a 24 tooth flat top grind ripping blade as I rebate out the material and leave the tongue. Grooves are just a crosscut with the ripping blade, basically a 1/8"x1/8" tongue and groove joint. This joint is commonly seen in cabinet drawer construction and where I first started using it many years ago. Interesting to see that Troels Gravesen also uses this technique.
                              Because these have to travel with me, I didn't want binding posts that would stick out so I cut a "cup" into the back panel after making it a little thicker.
                              Cross braces were made, you can see I changed my mind on how I was going to make them with all the different pencil marks on them. The furniture maker in me would not allow me to just glue the braces to the front and back of the speaker with the one long tongue due to different rates of expansion between flat plywood and stacked laminations of plywood. To put my mind at ease, I broke the 11" long "tennon" into three smaller tennons that would not constrain the front and back sandwiches.
                              Rather than attempt to glue the whole box up in one shot, I broke it down as much as possible, starting with just one side of one end, then the one side of the other end, the middle braces on just one side, then the entire second side. Takes longer, but makes for less stress.
                              Before the sides get glued on, lap both sides of the cabinet on a large sanding block, glue one side on, add damping where it needs to go, glue on the second side and flush trim the sides to the box. Driver holes have been taped up to prevent the damping from getting polluted with sawdust.
                              Click image for larger version  Name:	66 - cutting grooves in baffle.jpg Views:	9 Size:	307.2 KB ID:	931293
                              Click image for larger version  Name:	64 - all tongues cut.jpg Views:	9 Size:	275.0 KB ID:	931292
                              Click image for larger version  Name:	65 - test groove.jpg Views:	9 Size:	166.6 KB ID:	931291
                              Click image for larger version  Name:	66 - cutting grooves in baffle.jpg Views:	9 Size:	307.2 KB ID:	931301
Name:	63 - cutting tongues.jpg
                              Click image for larger version  Name:	67 - thicker for terminals.jpg Views:	9 Size:	404.3 KB ID:	931296
                              Click image for larger version  Name:	72 - jig for terminal cup rebate.jpg Views:	9 Size:	385.7 KB ID:	931295
                              Click image for larger version  Name:	73 - terminal cup rebate cut.jpg Views:	9 Size:	381.0 KB ID:	931298
                              Click image for larger version  Name:	74 - terminals test fit.jpg Views:	9 Size:	437.3 KB ID:	931300
                              Click image for larger version  Name:	75 - laying out for braces.jpg Views:	9 Size:	291.1 KB ID:	931299
                              Click image for larger version  Name:	76 - cuting braces 1.jpg Views:	9 Size:	361.8 KB ID:	931297
                              • DaveFred
                                • Sep 2018
                                • 172
                                Moor pics ...
Name:	77 - cutting braces 2 lots of chips.jpg
Name:	78 - cutting braces split tennons.jpg
Name:	79 - test fit braces.jpg
Name:	80 - test fit.jpg
Name:	81 - glue one end one side.jpg
Name:	82 - glue up braces one side.jpg
Name:	83 - glued up mostly.jpg
Name:	84 - lapping sides of boxes.jpg
Name:	85 - glue one side on.jpg
Name:	86 - install sheeps.jpg
                                • DaveFred
                                  • Sep 2018
                                  • 172
                                  And still moore,
Name:	87 - glue on second side.jpg
Name:	88 - flush trim sides.jpg
                                    • 998
                                    How did you use a forstner bit to make ovals? I would think after cutting one through hole the other would be difficult to keep straight?
                                    • DaveFred
                                      • Sep 2018
                                      • 172
                                      Hello Danny,
                                      The board is well clamped, no problems were had.
                                      David.
                                      • DaveFred
                                        • Sep 2018
                                        • 172
                                        InDIYana 2023 continues...
                                        -Shaping the cabinets-
                                        Building a square box was just the first part, next up was taking what I have learned from my tweeter bevel/roundover studies and shaping the box to allow for the smoothest frequency response.
                                        The big bevels on either side of the tweeter flare back at 30º and taper by 2-1/4" back into the baffle (hence the 3" thick baffle). There is also 1-3/4" double 30º bevel rising on the front vertical edges of the box on either side of the woofer that fades into the tweeter bevel. There is a smaller 1-1/8" double 30º bevel on the top and back of the box for aesthetic reasons. All bevels are softened with the 150g tool.
                                        My original plan was to use a jointer plane for the bevels, but Baltic Birch plywood endgrain turned out to be a lot harder to plane than I expected. I wasn't so sure about using a power handplane (slow mistakes vs. very fast mistakes) but it turned out to work much better than I expected. I only planed within about a 1/16" of my lines and used a large 60g sanding block to clean up the plane marks.
                                        The big bevels were tricky, but I would definitely do this again. If you plan on trying this at home, please practice on a test box, not one you have a ton of work into for your first try.
                                        Next up, finishing...
Name:	89 - LN low angle 7.jpg
Name:	90 - marking for big bevels.jpg
Name:	91 - DW power plane getting there.jpg
Name:	92 - DW power plane 60g cheese grater.jpg
Name:	93 - DW power plane side two rough.jpg
Name:	94 - more 60g tool.jpg
Name:	95 - 60g tool getting there.jpg
Name:	96 - second bevel done.jpg
Name:	97 - bevel close to layout lines.jpg
Name:	98 - bevels done one box.jpg
Name:	99 - 30 degree other double bevels.jpg
Name:	100 - other bevels cut.jpg
Name:	101 - sanding for finishing.jpg
Name:	102 - sanding for finishing.jpg
                                          • 15259
                                          This is a very interesting approach to a translam style speaker cabinet. The front panel geometry and layout reminds me a lot of some of the early Avalon speakers when my friend Charlie Hansen was running things. And I know where he got the idea to investigate this...
Name:	Avalon Ascent.jpg
                                            • 15259
                                            I would call this the "money quote".
                                            • DaveFred
                                              • Sep 2018
                                              • 172
                                              Woodworker, cabinet maker, furniture maker for 30+ years.
                                              Speaker builder, not so long.
                                              One of the beauties of not knowing what you are doing, is not knowing what you're not supposed to do.
                                                • 15259
                                                Great quote when it works in your favor!!
                                                No artificial boundaries on creativity!
                                                • DaveFred
                                                  • Sep 2018
                                                  • 172
                                                  This weekends update,
                                                  Put some Osmo Oil finish on the Seawaves, installed the binding posts and the drivers, made measurements in 10º increments 0º to 180º horizontally and -180º to +180º vertically, designed a crossover and did some validation measurements to ensure the design and reality matched.
                                                  Today's post will have lots of boring graphs, if anyone wants more detail about a specific slide, please ask.
Name:	103 - starting finish.jpg
Name:	104 - finish done.jpg
Name:	104a - binding posts installed.jpg
Name:	105 - starting measuring.jpg
Name:	106 - raw tweeter.jpg
Name:	107 - raw woofer.jpg
Name:	108 - raw woofer and tweeter.jpg
Name:	109 - tweeter with filter.jpg
Name:	110 - woofer with filter.jpg
Name:	111 - tweeter and woofer with filter.jpg
Name:	112 - measured woofer and tweeter with filter 0º - 60º.jpg
                                                  • DaveFred
                                                    • Sep 2018
                                                    • 172
                                                    Moar Piks...
Name:	113 - crossover schematic.jpg
Name:	114 - xo spl chart.jpg
Name:	115 - xo spl chart with reverse null.jpg
Name:	116 - Power and DI.jpg
Name:	117 - impedance.jpg
Name:	118 - filter slopes.jpg
Name:	119 - phase.jpg
Name:	121 - distortion 97db @315 mm or 88db @1m pct.jpg
Name:	122 - distortion 97db @315 mm or 88db @1m spl.jpg
Name:	123 - horizantal polar 0º - 180º.jpg
Name:	124 - vertical polar 0º - 90º.jpg
                                                      JonMarsh commented
                                                      Editing a comment
                                                      Pretty pics, and highlight a typical problem with obtaining directivity consistency in the vertical plane in the critical presence range. I wish folks like Seas would do a better job with coaxial like the C18EN we used in the Minerva. better driver performance and a vaguely reasonable price- I almost passed out today seeing the current price on the C18EN002!
                                                  • tktran
                                                    • 658
                                                    Yes. It's wisdom. Unfortunately it takes time.
                                                    So going back to the electric planer (yes I have one on order) does it work well with MDF?
                                                    Do I just draw out the lines with pencil and plane away? 1mm, 2mm, or 0.5mm?
                                                    Any tips and tricks much better.
                                                    Bye-bye roundovers and paint, hello facets and formica!​
                                                      JonMarsh commented
                                                      Editing a comment
                                                      Hmmm, this sounds a bit familiar, but the last speakers I did with "facets" of a sort and formica were the X1 SLAMM Klones in the 90's. Those were monsters... in more ways than one.
                                                    • 1879
                                                    Actually MDF planes pretty well ...... like most woods don't try to take too much material in a single pass.
                                                    • DaveFred
                                                      • Sep 2018
                                                      • 172
                                                      Small update for today, playing around with PR weight options.
                                                      Low end measurements with 0, 20 and 40 grams added to the Dayton DSA270-PR 10" passive radiator.
                                                      As my previous graphs show, I was having a little problem merging the passive radiator with the woofer and ended up with a peak at the low end.
                                                      Scott Hinson reminded me about the REW option to use "In the Box" microphone measurements and that is how these measurements were done, no merge required to see where the roll off is.
                                                      In the end I oped for no added weight and went with the green response.
Name:	125- drill hole bottom of cabinet.jpg
Name:	126 - mic inna box.jpg
Name:	127 - mic inna box 2.jpg
Name:	128 - PR weight options.jpg
Name:	129 - REW Mic inna box button.jpg
                                                      • DaveFred
                                                        • Sep 2018
                                                        • 172
                                                        With the PR weights all decided on, it was time to build the XO's, install them, wire up the drivers, button everything up and hope they met my expectations!
Name:	130 - starting woofer XO.jpg
Name:	131 - woofer XO 2.jpg
Name:	132 - woofer xo 3.jpg
Name:	133 - woofer xo 4.jpg
Name:	134 - tweeter xo 1.jpg
Name:	135 - tweeter xo 2.jpg
Name:	136 - all xos ready to install.jpg
Name:	137 - screwing in xo.jpg
Name:	138 - both xos installed.jpg
Name:	139 - installing drivers.jpg
Name:	140 - securing wires.jpg
Name:	141 - finally listening to the finished pair.jpg
                                                        I am very pleased with how they turned out!
                                                          Master of None
                                                          • Jan 2014
                                                          • 855
                                                          They look amazing! Did they meet your expectation???
                                                          Painter in training
                                                            • 15259
                                                            Finished in time for the competition?
                                                            • DaveFred
                                                              • Sep 2018
                                                              • 172
                                                              All done, shows over....
                                                              I liked them, I think a good number of people liked them, but a better design and implementation won.
                                                              • tktran
        • 658
        The directivity matching of this speaker is smoother than that of the other (winning) speaker.
        my theory- sighted listening tests have too many biases to be effective at detecting the preferred speaker. But supposed a double blinded study found the same result; what can we hypothesise?
        a) directivity matching is just not that important. 2) listeners in that room, listening in stereo preferred the speaker with the wider dispersion. c) circle of confusion strikes again.
        • 998
        Well they look fantastic, and I'm sure they sound great. Also great - that towering flexi-rack you have in the corner of your room! That's a lot of shelves!
        • Efalegalo
        • Jan 2007
        • 138
        my theory- sighted listening tests have too many biases to be effective at detecting the preferred speaker. But suppose a double-blinded study found the same result; what can we hypothesize?
        I literally had the same thoughts in my head.
        It is interesting, however, how many times the RS225 ends up in a winning combination. I have a few on hand but have yet to use one in a 2-way.
        In regards to directivity - I have built speakers with good directivity (e.g., waveguide loaded tweeter) and simple 6.5" 2-ways, and I've enjoyed both. I haven't compared the two through a blind-listening test.
        For me - I will take better bass extension over better directivity every time. I'm not a bass-head by any means, but I just don't enjoy music when some of the low notes are missing.
