Hi all
Looking for some suggestions for options for some hopefully tried and tested designs that might work as LCR's for our lounge area. Like most everyday lounge/family areas there are constraints and compromises everywhere, so Im just looking to try and make the best with what Ive got - Im not looking for reference level performance and Im the only one in the household that will be listening critically in the slightest!
The chief interior designer in the house made it known that looks trump everything (which is wonderful....), but I managed to reserve some real estate within the built in cabinetry, as can be seen in the photo; those 3 doors have speaker cloth within the door surrounds.
Im looking to try and squeeze matching (or at least complimentary) front speakers across the 3 cupboards, along with a sub at the bottom of each side. With a small mod to the Micro Marty Sub (detailed on AVS forum) I can fit those in, so that is my plan at the moment.
This leaves me with a space 460mm high x 635mm wide x 460mm deep (18" x 25" x 18") on each side, and 435mm high x 670mm wide x 460mm deep (26" x 17" x 18") for the centre. (apologies for metric - Im in Australia ).
My initial searching led me to the 88 Special at DIY Sound Group, which would fit pretty much perfectly (with a very small mod for the centre). However given Im in Australia, with poor exchange rates at the moment, along with the hassle, time and cost of shipping, has led me to wonder whether theres easier options available - the key aspect being that the design uses drivers and components that are more readily available to me locally; which is relatively wide ranging - just nothing that has been customized like the Denovo branded components, the Jansen JA-8008, etc.
My head has nearly exploded from reading through the forums here and at Parts Express - as well as over at AVS Forum where I typically frequent more often. Its interesting that the common theme at AVSF these days is seems to just "buy from DIYSG".
To further complicate matters Id ideally like to end up with something On Wall/In Wall for the rear surrounds; so a design "family" with options for this would be beneficial, although not critical.
I have Swopes in my head, Khan's, Statement Monitors, Modula's NatP's....... and Im going around in circles!
It may be that the easiest end solution does entail me bringing something in from overseas, but any thoughts or suggestions would be greatly appreciated - particulaly from the point of view of which options may work better (or less worse...) with the constraints Im going to place on them.
Budget I think is up to around $400USD per speaker, but thats probably quite arbitrary as well - as long as it looks nice the interior designer wont ask!
Please dont hesitate to ask for the dumb information Ive forgot to include...
Cheers & thanks
Baz
Cheers & thanks
Baz
