Ok, I've been a long time browser of htguide, just never registered. You guys are an absolute treasure trove of knowledge! I've recently taken the plunge into diy and to start out, as a first ever project, built Jim's TriTrix speakers with the parts express kit. Kit being CNC'd, all the cuts were pretty much perfect so construction was a snap. Being new to wood working (new as in the only thing I've built out of wood from scratch was a simple table made up of 2x4's and a particle board top)... I can't get my cuts perfect... There's about 16th to 32nd of an inch off at one or two corners on some of the boards... by some miracle, some are square. This is done with a circular saw and a self made rip, no table saw. Is this going to be a huge problem come time for assembly? I try to get one board as close to square as I possibly can with my limited tools then rough cut the other pieces of similar dimensions and flush route them to at least get them to be the same dimensions. Here's a photo of what I have cut up so far, all that's left are the tunnels and braces. I know they may look decent in the photo but close inspections with a ruler will say otherwise. I'm not sure how accurate cuts needs to be for speaker cabinets but hopefully with my poor cuts but I hope it'll at least look like a box when I'm done. If there's any words of encouragement and or advice, I would appreciate them. I will continue to update as I progress if anyone's interested. After seeing all the absolutely awesome talent that had already built these speakers on here, I feel very unnecessary to show off my less than poor woodworking skills. Thanks in advance!
Absolute Noob at wood working and am building Jim's Statement IIs
First of all, thanks for sharing and to contributing to the forum - thats great and useful information and interesting reading usually is the result. At the same time I'm quite sure you will be able to get help resolving issues and problems that may occure when traveling down the often not so straight DIY path :-)
About your question, how square do your cuts habe to be...
That might depend, but a little bit off can usually be handlet quite well.
I would say that 1/8 of an inch is borderline, maybe a bit mutch. 1/32 of an inch is normally no problem.
What you will experience is that you get issues when you try to assemble the box as it does not nessesarly fit that well.
The more experienced here normally adds a bit of overhang to some edges (like 1/16) and uses a router to shave that off after the box has been glued together. When using that method you can have quite large deviations without getting any problem. When you have to sheets you want to be exactly equal you may use clamps and put them together and then use a router to remove any excess wood.
I also often apply several sheets together and by doing that in effect cuts out several speaker sides at once.
A good stearingquide for your saw is a importand investment.
Also, as you see, a router is a invaliable tool when doing this kind of work.
Oh, I forgot that -'if stiff goes wrong, you always have boundo (for outside) and scilicon (for inside)-TEK
I agree with TEK.
My cuts are never dead on. If you look at some of my speakers closely, you'll see some bow or wow in the sides. Usually, clamping down tight can fix things. It will really depend on where you're over and under.
I normally use regular tightbond glue, but if you have some bigger gaps, you can use use a thick glue, like PL Premium Urethane http://www.loctiteproducts.com/p/pl_...n-Adhesive.htm it will fill and bridge small gaps. I've also used Bondo on a speaker or two to fix mistakes.
I always oversize my baffle, which is the last piece I glue down and then use a flush trim router bit to trim it up perfectly. Actually, I usually end up flush trimming all sides. My bigger problem usually is clamping square.
You'll figure it out. And the next speaker construction will be better than this one. and so on and so on.- Bottom
Thanks guys, I'll update as I go... hopefully there will be something useful for someone a long the way.- Bottom
If you have a router and a straight bit with a bearing, clamp the bad pieces onto the square ones and route off the excess.- Bottom
I do need to clarify that in spite of you and others giving me all the credit for the Statements/Finalists/Anthology's, they have all been a collaboration between the real brains, Curt Campbell and myself with our good friend Wayne Wendall jumping in to help with voicing. They get all the credit for how these speakers sound. If it weren't for Curt, I'd just own empty cabinets with drivers piled around them. ;x(
We're looking forward to following your build!
Jim- Bottom
Images not available- Bottom
Welcome to the Statements family! I hope you'll enjoy them as much as I do mine. It looks like everyone has given you great advice regarding building your cabinets. That's not my greatest strength so I'm glad others jumped in with answers.
Jim- Bottom
I have a question, I've searched but couldn't find a definitive answer. I'll be using Corning's 703 fiberglass board to line the cabinet walls. I've read that it may blow out the port and have fiberglass fibers fly all over my room. Some say it'll be fine. Should I cover it with speaker grill cloth or just spray that sucker and stick it on?- Bottom
703 is a semi rigid fiberglass. I've used it for years and never had an issue. If you're worried, give it a top coat of some spray adhesive. That will bind any loose material that may be there.- Bottom
I've used OC703 in speakers. There is no way 703 is going to blow out. It is rigid and glued together pretty well. Only possible scenario is if you have a cut edge with a flappy piece barely hanging on.
I've used regular R13 in speakers. I have it in my sub. Even that doesn't blow out the port. If people are getting insulation blowing out of their port, they must be putting some small loose pieces directly in front of the port. Keep the insulation held back from the port so as to not obstruct it.
OC703 will give react differently than the foam Jim used in his. You may have to experiment a little to get it to sound perfect. Especially with the mid tunnels. In fact, I would duplicate Jim's mid tunnels as much as possible, including how far he holds the foam back and the angle it is cut at. Use the 703 for the woofers.- Bottom
To clarify, I have used OC703 on a friends Statements in the woofer compartment only. I've never used it in a ported design. Definitely don't use it in the mid tunnels.
Just an FYI, if you buy the kit from Meniscus, it comes with everything you need to build them except for the cabinet.
Jim- Bottom
If the Jim you're referring to is me, I don't have a website. Curt does. :W
Jim- Bottom
Hi silvia0073! your going to LOVE your statements! i just paired mine up with an emotiva amp. this giants were made to be played loud! amazingly good. Post more pics please, we all love pics. And don't wait a year to do the finish/paint. I'm just about to get mine painted next month, about 2 years after the build. looking forward to seeing them progress- Bottom
Question, when wiring the drivers in the cabinet, do you guys use the same length of wire for the drivers or because it's so short, it doesn't matter?- Bottom
HTH
Jim- Bottom
Yes actually, probably won't finish till April or May, still deciding on what kind of finish I want. Besides, if I spend any more money on this project right now, my wife will probably kill me. lol.- Bottom
It was all gut feeling actually lol. I started with the back, didn't cut the square holes (drilled a hole to fit my trim bit and routed them once the tunnels are glued in), I glued on the top cover, bottom cover, braces, and then one of the sides. Built the tunnels then lined them up on the half constructed cabinet. Once that's nice and dry, I put on the other side panel. Sand everything smooth. I'm probably going to install the crossovers then insulation. Run wiring then cut the front baffle for the drivers. Install the front baffle and lastly, drivers. Hope to be done by this weekend. If I do complete construction, it took me 2 weeks to build... not including finishing. Not bad, but I stayed up late, almost to 3 am every day just taking my time and working it. Too excited to sleep anyway .- Bottom
Paradigm Studio 60 v.3- Bottom
That's a good question. Since building cabinets myself isn't a possibility , I was looking here https://melbyaudio.com/products/stat...lat-pack-kit-1 and I don't know if they do it either.- Bottom
Well Hot Damn... if I had to do it all over again, I'd go that route, maybe, just buy and assemble myself... All the tools I used on my Statements, I purchased new just for the project. Router, drills, drivers, clamps... etc all came out well beyond $500, but I must say, the experience was priceless... Those guys are just a few hours from my place and being CNC cut... can you say perfection? LoL, I'm tempted just because it's CNC'd. If any of my friends want statements, I'll go that route.- Bottom
Half the fun of a new project is justifying new tools. :W- Bottom
same here TEK. although i can see the massive benefit of getting everything cut i really enjoyed the whole process - even when the router slipped and i had to redo a front panel! i guess at the end I'm glad i built/cut them and now i have a bigger garage theres not a lot i won't take on with the skills i learned. MDF dust sucks though...- Bottom
Done!!! Now for the burn in, already it sounds fantastic. When hooked up to my Yammy RX-V2095... ehhh, sounds ok. Played for about an hour and it's now in my PC room and hooked up, kinda messy so I'll take photos later but here's one of them hooked up to the yamaha. They sound pretty darn awesome on my pc with flac files. Can't wait for them to be properly broken in... all I have to say is wow, the vocals are simply amazing!!! This build has been no where near perfect but as I listen to them, all the imperfections melt away and I love them more and more with each minute. Thanks again for an awesome design Curt, Jim, and Wayne!
