Roundover on sealed design, will it make a difference?
  • xyrium
    • 118
    Hey guys,
    So, I've got the interior of the cabs, the soldering and mounting of the xovers, and the routing of the baffles complete for the ZRT design. However, when sorting through my tools, I was unable to locate my 1/2" collet for my 3/8" roundover bit. This said, since this is a SEALED version of the ZRT, will a roundover make any difference?
    Paul
    Paul
    • 5568
    Sealed or anything else, yes. How much? Depends.
    • xyrium
      • 118
      This kills. Maybe I'll just take a rasp to it...
      Paul
      • lunchmoney
        • Jul 2008
        • 152
        yikes... that would be tough to do cleanly with a rasp
        take a deep breath, then go buy a new collet
          • 5568
          3/8 is going to be minimal change - far less than the somewhat more common 3/4" roundover or a bezel, though not nonexistent. A little felt treatment around the tweeter will likely ameliorate any issues leaving it square. A ~3/8 bezel may have good results too (though again different), perhaps that's easier for you to accomplish?
            • 5202
            Can you do a 45d chamfer on your table saw? If so, do a ~3/4" chamfer.
            • xyrium
              • 118
              Yeah, I ordered the collet just before I posted this thread. I suppose I'll just have to wait. I'd rather do it right than half a$$ it.
              I have several bits, but figured the 3/8 would least impact the structural integrity of the baffle. However, maybe I'll go that extra mile and try a 5/8 or 3/4. The drivers are fairly close in this design, so I figured the more meat I leave between them, the better isolation. I'm searching for the best compromise, so maybe a 1/2" roundover is it.
              I could get 45 on my table saw, but how am I going to get a 10" blade into a 6-3/16" circle? I'm actually doing a roundover on the interior of the baffle for the woofer cutout, not the edges of the baffle where it meets the side/top/bottom of the cabinet. I should have clarified that, sorry guys!
              Now I sit and wait for UPS...probably until next Tuesday or so. Don't buy a Hitachi router. Though I think the unit itself is actually quite good (KM12VC) it's impossible to get parts for, and forget accessories. I should have stuck with Bosch or Porter Cable....
              Thanks!
              Paul
              Paul
                Ahh - you mean inside the woofer cutouts rather than the outside baffle edges.
                Actually you'd be better off with a chamfer than a roundover there. The idea is to give the woofer more room to breathe.
                Somebody, maybe Zaph but I cannot find a link, posted results of tests with or without the chamfer on some small drivers. Very worthwhile.
                  • 5568
                  Ahh snap.
                  I often use an ogee bit for driver relief. Or a 45 chamfer.
                    • 5202
                    I've done a driver openings with a rasp. Worked okay. In some ways, better than a router. But the edge of a box I would stick with a router so that the box impresses people.
                    • lunchmoney
                      • Jul 2008
                      • 152
                      Ahh as well... I also thought you meant roundovers on the sides of the baffle...
                      How thick is your baffle? If it's 3/4" or less, it's probably not that big of a deal if you skip the inside chamfer.
                      • robfive
                        • 24
                        Go to town with the rasp. It will work well.
                          • 571
                          Maybe this from Troels?
                          The Importance of chamfering driver holes
                            • 5568
                            Zaph has published data on the importance of this as well. Don't neglect it. But yeah, for interior work, a rasp would have been adequate.
                            • xyrium
                              • 118
                              Thanks guys. Once the collet arrives, maybe I'll do a chamfer. I'll have to check my bit collection, I think I might have something.
                              Edit: I have a 45 degree 5/8" chamfer bit. The baffle is 1" thick, but given the proximity of tweeter to woofer, I might stick with the 3/8 or 1/2" roundover though.
                              Paul
