8 ohm CC designs?
  • Paul Ebert
    • 402
    8 ohm CC designs?
    Is anyone aware of an 8 ohm CC design? I may need one for use with my HK AVR 154. The mains and surrounds will be Module MTs, so something using the Dayton RS series would be nice.
    Alternatively, could anyone suggest how I might create such a design? I've been modeling various configurations (MTM, MT/WM, etc) with various (RS) drivers, and they always seem to dip well below 5 ohms in the higher frequencies.
    I could simply use another Module MT, but I'd rather not have it be that tall.
  • Undefinition
    • 577
    Good point. If you want to keep the "sideways MTM" thing, then use two woofers in series. Should have no impedance issues there.
    There seem to be very few MTMs with the woofers wired in series (TriTrix and Tubifex are the only two that come to mind); I don't know why this is.
      • 5568
      Modular uses a 4ohm or 6ohm tweeter...
      A pair of 4ohm mid-woofers would work, but horizontal mtm is not the best choice ever... I would take the extra height and a modula mt.
        • 5568
        dang phone. Fixes ohm stupidly.
        • Undefinition
          • 577
          Yes, but... he could do a W/TM/W setup, with the woofers in series, and still stay in the safe zone of impedance. Eh? Eh? :W
          • Paul Ebert
            • 402
            Yeah, a WT/MW is my thought too. But, when I try with 4 ohm woofers (in series) and 8 ohm tweeter and mid, I get system impedances as shown on this link:
            RS180-4x2 RS52 Aura NT1 system impedance
            I can't seem to do anything with the mid and tweeter filters (or woofer, for that matter) to raise the impedance above 200 hz. Any ideas?
            • Undefinition
              • 577
              Could you email me your project files? I might be able to help.
                • 5568
                You're not working with 8ohm drivers above 200Hz... - so you're not going to be able to get impedance up.
                • Paul Ebert
                  • 402
                  Well, the RS52 has a (rated) Re of 5.4 and the Aura NT1's Re is 6.96. Perhaps I could find drivers with higher values, but should I need to?
                  • Paul Ebert
                    • 402
                    Paul, I'd be happy to email the files. Could you PM me your email address?
                    Thanks!
                      • 5568
                      Can you share the topology? Even that can give tips on what you could change.
