Crossover help
  • jeffc52053
    • Apr 2009
    • 16
    Crossover help
    I've recently built 4 TM's and 1 MTM for HT. For the MTM I used Audax 6.5" (2) and a Morel CAT378 Dome tweeter. The 6.5's are rated at 89 Db and the Morel is rated at 93 Db. The TM's are Pioneer 6.5" and the Morel CAT378. The Pioneer is rated at 93 Db. I wanted a very dynamic system which is why I chose these drivers. However, the 6.5's have a very ragged FR starting at about 4000 Hz. I built a textbook 18 Db/oct crossover at 2250 Hz and would like to build a really good crossover for these.
    I have 2 JBL 10" subs for the bottom end.
    Help!
    • 5568
    Where are you located? Getting accurate measurements is usually the best place to start.
    • jeffc52053
      • Apr 2009
      • 16
      Crossover help
      I'm from Utica, NY.
      I don't have any test equipment but I do have the manufacturer's FR graphs. I tried Jeff B's SPL TRACE and his crossover software without much success. Apparently SPL TRACE doesn't like graphs done in black ink and I can't figure out how to change the color of the FR graph so SPL TRACE can see it.
      • Rick Craig
        • 391
        Originally posted by jeffc52053
        I'm from Utica, NY.
        Jed from Clearwave lives in NY and maybe he could help you.
        • jeffc52053
          • Apr 2009
          • 16
          Thanks Rick...
