Dayton RS28F-4 Reference Silk Dome!
    • 1454
    You asked for it, you got it. :B
    I've probably missed the discussion on this new unit, but I just now noticed it in the new flyer. 1-1/8" silk dome, 88db sensitivity, FS=541hz for about $48. Plus they have replacement diaphrams already. Boy would I love to try this one out!
    Last edited by theSven; 10 June 2023, 20:50 Saturday. Reason: Update image location
    Dan N.
  • Curt C
    • 791
    I'll have a couple next week for evaluation... I'll let you know how it looks.
    I wonder if the fabric diaphrams will interchange with the original metal dome chassis?
    Curt's Speaker Design Works
      • 1454
      Great, I'm anxious to see how they measure and hear how they sound.
      Wouldn't that be interesting if you pop one of those fabric diaphrams into an existing metal dome chassis! Great question Curt.
      Dan N.
        • 5568
        Sensitivity is so low though
        • Silversmoky
          • Nov 2007
          • 178
          I was surprised as well to see the sensitivity at 88. Still, I do like the looks of this new tweeter. I actually thought it was a misprint when I saw it labeled as a silk dome tweeter in the new flyer!
          • JoshJK
            • Jul 2008
            • 15
            88 dB seems to be with 1 watt input, not 2.83 volt.
            • Jonasz
              • 852
              I think it's ugly...but that doesn't mean much if it delivers! :P
                • 1454
                One guy over on the PE board reported that he had stopped by PE on his way home and picked up a couple of them. They have the sensitivity sticker on the side as did the RS28A metal domes and I believe both of his were marked 90.2db, FWIW.
                Dan N.
                • Mark K
                  • Feb 2002
                  • 388
                  I'm borrowing a pair of these, hopefully this weekend, so I will likely post some measurements by next week. I should also have an SB dimple dome pair to test.
                  www.audioheuristics.org
                  • Mark K
                    • Feb 2002
                    • 388
                    I've got a pair, along with some dimple dome and TB titanium tweeters. Look for some new test data in the next week.
                    • jquin
                      • 135
                      Excellent, I HATE metal tweeters.
                      It might make the Modula MT really nice. (Well more to my liking).
                      Sadly I have three RS28A's that need to be doing something. I wonder if it is worth putting them on ebay.
                      • augerpro
                        • 1866
                        Wonder how different they are from the Usher 9950?
                        ~Brandon 8O
                        DriverVault
                        Soma Sonus
                        • fjhuerta
                          • 1140
                          I like them. I'm a big fan of metal tweeters, but I wouldn't mind trying them out.
                          Javier Huerta
                          • Mark K
                            • Feb 2002
                            • 388
                            I've finished testing these, but don't have the results posted.
                            The motor is the same as the nonferro/old ferro RS28A. Double copper which is different from the 9950 IIRC, The consistency between the two is very good and distortion performance is very good even to 1-1.3k.
                            Sensitivity is 90-91db/2.83v
                            Another solid performance. Now if only Usher, er, I mean Dayton can come up with a lens/waveguide that looks, well, remarkably similar to the DXT.
                            Or, even better, a jumbo sized DXT clone, 6-8" mounted on their motor. After all, Usher is really good at copying stuff... :E
                            I've been impressed with the nonferro RS28A's. Looks like the QC has improved significantly.
                            PS I didn't have a new nonferro pair but I suspect the domes are interchangable.
                              • 5568
                              Impedance really similar then? Wondering if these are a direct swap for the 28A or not. They sure sound like it, and would provide a really nice additional option for a lot of existing designs. I just might have to snag a pair and try them in my big 3-ways.
                              • fjhuerta
                                • 1140
                                Will they run lower than the metal RS28's?
                                Javier Huerta
                                • Mark K
                                  • Feb 2002
                                  • 388
                                  No I don't think so. But the newer, nonferro versions of both the metal and fabric seem more consistent overall. I think you could reliable try 1.3 in a two way.
                                  mark
                                  • Mark K
                                    • Feb 2002
                                    • 388
                                    Measurements up
                                      • 3223
                                      Originally posted by Mark K
                                      Hi Mark,
                                      As always, excellent work!
                                      Can you share any opinions on how the RS28F compares to the HDS?
                                      Thanks!
                                        • 10934
                                        We don't need two threads about the same tweeter.
                                        Given how the threads have evolved merging them would create a mess.
                                        So.....
                                        I'm closing this one, please put further posts in the one running in the drivers wanted section.
