Zaph's new SB Acoustics 3-way
  • benchtester
    • 213
    He's at it again:
    Kit can be found at Madisound:
  • evilskillit
    • 468
    Hrm, one word. WOW. He's right everybody makes small or skinny speakers these days. It is refreshing to see something that isn't afraid to say, "I've got a huge woofer. What of it?" I'd love to hear a pair.
    • A9X
      • Jan 2007
      • 107
      Interesting. I was wondering about a smallish bedroom speaker, and this might do it, especially as I'd rather single amp there.
      • DeathMonk
        • Jun 2008
        • 232
        I agree
        Maybe I'll build a pair down the road.
        • Jonasz
          • 852
          Exactly!
          Small speakers suck! :twisted:
          This is definitely a step in the right direction... :P
          • kingpin
            • 958
            It's starting to look like the larger speaker designs using 12" or bigger woofers are making a comeback. Just look at all the high efficiency designs popping up that are geared more for dynamics.
            Call me "MIKE"
            • numberoneoppa
              • 535
              Wow, these speakers look awesome (not just aesthetically). They're quite a bit over my price range, though. :P
              -Josh
              • A9X
                • Jan 2007
                • 107
                These are only 88dB/W
                • kingpin
                  • 958
                  oops! Guess I missed that part. ops:
                  Call me "MIKE"
                    • 16075
                    88dB isn't the inefficient. Honestly with how some of the speaker companies bloat their specs I bet 88dB would be more efficient then you'd think
                    • Curly Woods
                      • 125
                      Madisound is listing efficiency as 92db. Where did you see the stated 88db?
                      Mike Mastin
                        • 5202
                        Wow. Great write up by Zaph. Very well thought out and implemented design.
                        I think the popularity of speakers like the Statements shows that there is a big market out there for bigger and more expensive DIY kits than the budget kits. I think this is a great thing for our hobby, and really appreciate the work that Zaph is doing.
                        • stangbat
                          • 171
                          Zaph also lists it as 91-92 dB on the speaker's design page.
                          • jkrutke
                            • 590
                            Hi all, thanks for the comments. It was a fun little project. I've got an email address set up for this one to answer some questions.
                            He probably got it from the SE T/S parameters page. The SPL number on the T/S parameters is an efficiency number based on one watt and is calculated rather than actual. The SPL shown on the response graphs is a sensitivity number based on 2.83 volts and is actual rather than calculated.
                            Anechoic 2.83V system sensitivity for this is indeed 91-92 dB. (92 up through the midbass, about 91 above that) It's not as simple as anechoic woofer minus baffle step however, the woofer's proximity to the floor and the large baffle width complicates an estimate of system sensitivity as compared to small 2-ways.
                            I'll go into that a bit more when I write up the FAQ. I've already had a few questions on the subject.
                            Zaph|Audio
                              • 3223
                              Hi John,
                              I also wanted to add to the many congratulations on a job well done. :T
                              I appreciate a large full bodied speaker and I'm looking forward to hearing them. I have yet to hear any SB Acoustics designs. They are of particular interest to me, both woofers and tweeters.
                              • WillyD
                                • 675
                                Oh wow. This system looks great. Would love to build a pair of these one day.
                                • Bastek
                                  • Apr 2008
                                  • 41
                                  I love big speakers, they all sound great in my basement.
                                  I think these will look great with a black rubber foam pad to cover the space next to the MTMs. Will that change the sound character of the speakers?
                                  • djg
                                    • 57
                                    You could bury a monkey in that cabinet. Seriously, very impressive. Should replace the dated Magna C*m Laude project over at PE, and sound much better.
                                    • dumaresq
                                      • Mar 2008
                                      • 96
                                      I love big speakers too, but the room placement is crazy!
                                      "It probably goes without saying, but I'll say it anyway - This system is designed with large rooms in mind. Ideally, the baffles should be at least 4 feet out from the back wall, and 5-6 feet from the side wall. This is not the system to use if you have a 12 foot room with a 60" TV in it."
                                      You need to have a room that is pretty wide!
                                        • 3223
                                        Hmmm.... Not all big speakers require clearance like that. This a picture of my listening/home theater room which is 15'x20'. The Statements have 18" of clearance from the sidewalls and from the wall behind the speakers. Plus, there's a 61" TV between them. They sound great! :W
Name:	Statements Home Theater-cropped0003_NW (Large).jpg
                                        Last edited by theSven; 10 June 2023, 10:45 Saturday. Reason: Update image location
                                        • Jinjuku
                                          • 17
                                          Still hoping and holding out for a ZA5/Vifa/RS225 MTMWW 3way :B
                                          Wishing I had the design chops
                                          • Bastek
                                            • Apr 2008
                                            • 41
                                            With untreated rooms you should keep the distances recommended by Zaph.
                                            With room treatment and bass traps you can place them closer to the walls, but not less than 2-3 feet depending on BSC. It's also a personal preference, deeper soundstage vs accurate imaging. My big speakers don't like the walls in my 20x20' basement.
                                            Last edited by theSven; 10 June 2023, 10:44 Saturday. Reason: Remove broken image link
                                            • numberoneoppa
                                              • 535
                                              Your wife didn't shoot/castrate you for that?
                                              -Josh
                                              • Bastek
                                                • Apr 2008
                                                • 41
                                                Everything in that room is temporary, i swap speakers-treatments almost monthly, i think the highs have more sparkle-clarity without the ceiling foam, so that have to go. I don't really care how it looks as long as it sounds good.
                                                BTW, what is a "wife"?
                                                • kevinp.
                                                  • Apr 2008
                                                  • 107
                                                  so forgive my ignorance, what about big speakers dictates the size of the room or placement to walls besides BSC? Realistically, aren't larger drivers more directional than smaller ones at any given frequency?
                                                  • augerpro
                                                    • 1866
                                                    Zaph I wonder if you could share any impressions of the DQ25 versus the SB29. If not subjective, then maybe how directive the SB29 is at lower frequencies (3-6khz) than the DQ25. I have a sample of the neo SB29 and I could pretty much drop it in to my BBV2 for a truly no compromise design, but my experience tells me a 25mm dome may sound quite different than a 29mm ring radiator, and in the past I've sided with the smaller dome, even if the behavior wasn't quite as nice. Example: Peerless HDS over the SS9800 and XT25.
                                                    ~Brandon 8O
                                                    DriverVault
                                                    Soma Sonus
                                                    • fjhuerta
                                                      • 1140
                                                      Zaph, this one left me speechless. I just wished I could build that speaker right now... I'm sure it'd last me for years and years! I LOVE IT!
                                                      I'd love it if you could go deeper into how you measured the woofer section. I read your write up, but I couldn't really understand how you did it. The woofer, being so close to the floor, will never behave in a way I can understand how to model. I suppose there's no BSC, but I don't know how I could double check that assumption.
                                                      From what I could understand, it was the most complex part of your design. I surely hope you could go deeper into the subject.
                                                      Javier Huerta
                                                      • jkrutke
                                                        • 590
                                                        I've got the neo SB29 on my test baffle right now, and I can always get the DQ25 on it right after for some off axis comparisons. I plan on doing some power handling comparisons also. I would expect the SB29 to fare better in this regard but we'll see. Also, I've been meaning to get some vertical vs horizontal plots of the DQ25 to see if the oblong phase shield is doing anything.
                                                        I've got that question already asked and answered in the FAQ section, which I'll post tonight after I check it for spelling and grammar. It's not too hard, really.
                                                        Zaph|Audio
                                                        • augerpro
                                                          • 1866
                                                          As far as I remember there isn't a lot of difference, but with the shield vertical the high frequency null seems to be slightly smaller over more a wider angle horizontally. That's the way I'm using it currently, but I should look at all the measurements again to make sure that was the case.
                                                          ~Brandon 8O
                                                          DriverVault
                                                          Soma Sonus
                                                          • augerpro
                                                            • 1866
                                                            John here are the plots of the DQ25 off axis on my BBV2 speaker, 0-10-20-30 degrees.
                                                            With the shield vertical:
                                                            And with it horizontal:
                                                            Not as much difference as I thought. I'd be curious if you measure the same.
                                                            Last edited by theSven; 10 June 2023, 10:42 Saturday. Reason: Update image location
                                                            ~Brandon 8O
                                                            DriverVault
                                                            Soma Sonus
