Blown Crossover?
  • derekbannatyne
    • 196
    Blown Crossover?
    Hey Everyone, just wondering if someone could shed some light on a problem I'm having. Long story short, I came back one night and one of my roommates had turned up my Modula MTs too loud and now both my tweeters (Seas 27TDFC) are not functioning.
    I'm sure it's the crossover that's bad, as I can directly connect the tweeter (at low volumes) to my receiver and everything works fine. Also, the woofer doesn't make any sound if I connect it to the tweeter outputs.
    Is there any way to test individual crossover components? I have a basic digital multimeter that will measure resistance and voltage.
    Thanks for the help!
    • 10934
    The resistors are probably toasted. The other components are pretty hard to damage..
    • evilskillit
      • 468
      Wow, I think I might end my room mates life. Even if it does just end up being a couple of dollars worth of resistors the fact that they took something that you put so much time and money into that is a piece of precision engineering and just cranked it till they broke it... Grr.
      Anyways, good luck getting your speakers fixed, hopefully its nothing.
        • 5202
        Wow. I'm just wondering how loud he was listening to them? I'm picturing a small apartment where the levels it would take to blow them would be quite loud.
        If you want to add a little extra protection, you could double up the resistors when you re-build them. Resistor values don't add, they add inversely.
          • 1345
          Here's a story for you: I built a set of towers about 8 years ago and laid out the crossover boards carefully, with the wire routing a thing of precision beauty and economy. I put a right angle bend in one of the resistor leads; however, I didn't notice that I had crimped the bend too tight and had reduced the cross-section of the lead by ~50%. Months later, the tweeter in that speaker went silent. I figured I'd fried its voice coil, impossible as that sounds. Examining the xover, I saw the resistor swinging in the breeze, having melted at my precision right angle bend. ops: numnuts
          • aweil
            • Feb 2009
            • 26
            You don't know what you're talking about, do you?
              • 5202
              Wow, that was rude. Hopefully, you were just running short on time and didn't have enough time to fully explain your answer, rather than just being a rude. FYI, rude people don't last long here.
              It's been a long time since my freshman electrical engineering course, and I think you may be right. I've seen parallel resistors offered as a suggestion in the past and it was the first thing that came to my mind.
              Maybe you would care to explain it for all of us and offer a useful suggestion.
                • 3791
                I knew what you meant, Ryan.
                Parallel R = 1/(1/R1 + 1/R2 + ... + 1/Rn)
                  • 5202
                  Thanks Dennis. That is exactly what I meant. I was in the process of typing that out myself in the first response, but the boss walked in and it was easier to erase the last sentence than to finish it.
                  Then I got that response and started to doubt myself. Good to know my brain hasn't gone to total mush.
                  • derekbannatyne
                    • 196
                    Thanks for the responses!
                    I took out both of the crossovers, and it looks like the 8 ohm resistors fried (there was a black pool of some liquid underneath them). I just placed an order for new 12 watt resistors, hopefully the extra 2 watts will provide some extra protection.
                    And I have no idea at how loud he must have been listening to music, our living room is maybe 10x12 feet - must have been painfully loud. I'm not too upset about it, but I was definitely a little pissed off when it happened. But it shouldn't take too long to repair, and stuff happens.
                    Hopefully this will do the trick!
