Subwoofer Eq'ing
  • yousuredo2
    • 206
    Subwoofer Eq'ing
    Its been a while...
    I want to Get caught up on any recommendations on sub woofer eq'ing/feedback suppression/etc
    I am currently looking at two:
    ~ dsp1124p
    ~ fbq2496
    Any new/better choices available.
    musicianfriend.com has a (phone In)coupon for 20% off on select items.(exp. 10/31)
    hoping to utilize it
    My System
    ~ Onkyo tx sr805
    ~ Sony PS.3
    ~ Xbox 360
    ~ Natalie P's Main L/R
    ~ Polk Csi A6 -Center
    ~ Polk RTi6 Rears
    ~ Behringer ep2500
    ~ Behringer Fbq 2496
  • NoDestiny
    • Jan 2009
    • 97
    No experience, but eD audio has treated me well in the past. I was looking at this model myself...
    My experience with Behringer products has been... well... bad. But I have not used those specifically and I hear good things about them.
    • soundemon
      • May 2009
      • 136
      This Elemental designs EQ is pretty limited, having only 2 channels, and each of them limited in what frequencies they can effect.
      The behringer products I understand can be quite effective but difficult to learn and understand how to use.
      I use a rane PE17 5 channel analogue EQ, with REW. it can be a little frusterating too, but effective.
        • 10934
        The decision is this, do you want to be able to toggle between separate/different EQ settings for HT, music, etc.?
        If so get the DSP1124P
        If one stereo (2 channel) group of settings is all you need get the FBQ 2496. It's much easier to operate compared to the 1124. It has a wider choice of filters settings than the 1124P.
        • yousuredo2
          • 206
          Sorry guys, guess I should provide a little more details.
          It is going to be used in a dedicated home theater.
          (movies & games mostly, very little music, & no TV)
          Amp Is a Behringer Ep2500
          Sub woofer to be determined (tempest/maelstrom/???/???)
          easy to set up is a plus...I am not a audiophile, just getting my feet wet.
          sound quality isn't a huge concern yet, but I might want to tweak later down the road
          Is a mic, PC, calibration software, etc. needed for both/either ?
          My System
          ~ Onkyo tx sr805
          ~ Sony PS.3
          ~ Xbox 360
          ~ Polk RTi6 Rears
          ~ Behringer ep2500
            • 10934
            Get the FBQ2496, it's significantly more intuitive to operate compared to the 1124P
            You're not going to calibrate anything. This is EQ
            Mandatory for EQing is having the ability to generate test tones (or sweeps) and the ability to measure how loud those tones/sweeps are. This is most easily done with the RS SPL meter (or another brand with a line out) feeding a PC running Room EQ Wizard freeware.
            More accurate testing is done using a mic with a mic pre-amp with phantom power.
            • yousuredo2
              • 206
              The FBQ2496 it is then...
              ThomasW:
              Do you have a recommendation for items needed, along with the FBQ2496.
              I am on a budget at the moment, but I can buy a piece at time if necessary.
              Is the behringer mic/Dayton pre-calibrated Mic at PE what I need ?
              What else, as far as getting the subwoofer to preform as needed in a HT ?
              thanks again
              chris
              My System
              ~ Onkyo tx sr805
              ~ Sony PS.3
              ~ Xbox 360
              ~ Polk RTi6 Rears
              ~ Behringer ep2500
                • 5202
                You need a Radio Shack SPL Meter. Everyone needs to have one of these. For a subwoofer EQing, you can use one of these as you mic. Skip the PE mice for now, you don't need to get that fancy.
                Then you need some cables. You can either use RCA cables w/ 1/4" MONO adapters or use a rca->xlr cable and xlr-xlr cable between the amp and the FBQ. I do the latter.
                  ThomasW:
                  thanks again
                  chris
                  If you can spring for it now, Herb is going to get another batch of the EMM-6 mikes and calibrate them (see the EMM-6 thread). There's a fair discrepancy between Herb's measured response and that provided with the mike. You'll want a properly calibrated mike if you are going to go much past basic sub setup (for which a RS SPL meter and generic calibration file are typically good enough.)
                  • penngray
                    • 341
                    FWIW, I remember measurements some where showing the EQ.2 having high distortion when the gain was turned up.
                    I have never read about bad measurements with the Behringer products.
                    I have both and I like the EQ.2 for its simplicity, its SSF but its EXTREMELY limited outside of that. I set the gain to 50% too so Im not getting much distortion/
                    • yousuredo2
                      • 206
                      FBQ 2496 is ordered...
                      Coupon Code: OCT20% (Valid for phone in orders only by calling 1-800-687-3022)
                      expires 10/31/09
                      with coupon code total was $119.99 shipped
                      Now to start saving for the other items...
                      still debating on the subwoofer
                      so far it's between 2 Tempest, or 1 Maelstrom, or ???
                      Last edited by yousuredo2; 27 October 2009, 16:51 Tuesday. Reason: added exp. date
                      My System
                      ~ Onkyo tx sr805
                      ~ Sony PS.3
                      ~ Xbox 360
                      ~ Polk RTi6 Rears
                      ~ Behringer ep2500
                        • 5202
                        still debating on the subwoofer so far it's between 2 Tempest, or 1 Maelstrom, or ???
                        Those are probably your best options for output/$$. Those would be the ones at the top of my list, since I like a lot of boom with my movies.
                        • yousuredo2
                          • 206
                          The Fbq2496 and cables to hook it up to the ep2500 arrived today...
                          I need a splitter (AVR only has one sub out rca)
                          I have not installed it yet though.
                          this thing is going to take a minute to understand.
                          once I do, things should be easy(easier)
                          My System
                          ~ Onkyo tx sr805
                          ~ Sony PS.3
                          ~ Xbox 360
                          ~ Polk RTi6 Rears
                          ~ Behringer ep2500
                          • kevinp.
                            • Apr 2008
                            • 107
                            can you use the FBQ2496 or DSP1124 to alter phase?
                              • 10934
                              No..
                              • kevinp.
                                • Apr 2008
                                • 107
                                thanks Thomas - is there a solution for those using pro amps and EQs? Does changing the distance in AVR settings change the phase?
                                • yousuredo2
                                  • 206
                                  Any Pointers ?
                                  I know that the final outcome will be room, sub, etc specific...
                                  ~ But a good place to start for sub eq'ing ?
                                  ~ Types of filters used ?
                                  ~ What tones/tunes are used to help set it up ?
                                  ~ Bandwidth adjustments
                                  any guidance at all is appreciated till i get a full understanding of how to use it.
                                  My System
                                  ~ Onkyo tx sr805
                                  ~ Sony PS.3
                                  ~ Xbox 360
                                  ~ Polk RTi6 Rears
                                  ~ Behringer ep2500
                                  • kevinp.
                                    • Apr 2008
                                    • 107
                                    hometheatershack.com has tons of useful threads on sub EQing. They have a free program called REW (Room equalization wizard) that is pretty user friendly. You need an SPL meter or mic/preamp, an outboard soundcard with line-in or RCA jacks, and a laptop or PC in the room.
                                    REW link
                                    • FroDaddy
                                      • 274
                                      I use a Behringer 1124 and an Elemental Designs eQ.2 for the subwoofers. It was tricky to EQ but the tandem helped tune frequencies below 20Hz. There was a significant signal loss using both, but I was able to turn up my amps and the pre-out to compensate. I use a RadioShack SPL meter with REW to take measurements. Over time I've worked my house curve to suit my preferences. I'm considering bumping up the 20-30Hz mark in the future, but this is the REW housecurve specs I'm using right now.:
                                      21 16.5
                                      24 11
                                      30 1.25
                                      40 -4.5
                                      50 -9.25
                                      90 -10
                                      200 +1
                                      I adjusted the house curve to roughly fit my natural room response, and then I would adjust the curve so that I could fine tune areas with tighter tolerances. Here was the final EQ graph after integrating the eQ.2 into my system:
                                      The second channel of the 1124 is the EQ for my ButtKickers. As a guide I had to reference familiar movie soundtracks and cross reference the scenes to waterfall charts. Then I created a house curve then made parameter changes to try and visualize what I felt needed to be adjusted. After a lot of trial and error I'm very glad that I did it.
                                      I manually input EQ settings in the 1124 and don't find that difficult.
                                      Good luck!
                                      • kevinp.
                                        • Apr 2008
                                        • 107
                                        21 16.5
                                        24 11
                                        30 1.25
                                        40 -4.5
                                        50 -9.25
                                        90 -10
                                        200 +1
                                        Good luck!
                                        do you mean to say you're using 16.5db of gain at 21hz??
                                        • FroDaddy
                                          • 274
                                          No... Hopefully the OP doesn't mind going in this tangent for a bit. The graphs I'm posting vary with the dB reading since I had to use different base dB for two reasons: I used a laptop when using the eQ.2, and increasing the amp gain and sub out was needed. So when comparing my graphs it has to be done relative to the house curve line.
                                          Here was the EQ graph with only the 1124, no eQ.2 (note that smoothing is on):
                                          Then I put the eQ.2 in place I had line level signal loss even in "bypass" mode. After some adjusting, I had the cleanest signal by turning up the subwoofer amp and increasing the receiver's subwoofer out. So the next graph is a measurement using the same 1124 EQ filters, but with the extra signal gain:
                                          The room mode and amp/receiver gain played a big role in the 16hz spike. A point to note here is that the eQ.2's subsonic filter controls the woofers so well that it allowed me to turn up the amp and receiver FAR past the point of normal safety. So there is a boost/cut around 16Hz and I believe the effective electronic boost is +4.5dB at 14-15hz. Two other electronic boosts are done with 1124 and they are a +2dB at 21Hz and a +3dB notch boost at 55Hz. Everything else is a cut, and the upper end is cut so dramatically to blend in as seamless as I could get with the L/C/R mains crossed over at 60Hz. (Reference the first graph I posted here for the final EQ.)
                                          So in summary the end result with the eQ.2 was +10dB at 21Hz and +16dB at 16Hz. To get there the eQ.2's subsonic filter allowed me to unlock more excursion by adding more power, gain, and electronic boost. It was tricky to EQ since the eQ.2's dials aren't accurate, but I can't recall a better "bang for my buck" mod I've ever purchased. I'm glad a friend of mine talked me into trying it out!
                                          Sorry to the OP if I've taken this thread in the wrong direction ops:
                                          • yousuredo2
                                            • 206
                                            alright fellas if I am going to need a pc that can run rew what do i need to look for in laptop as far as sound card mic compatibility
                                            option #2,
                                            i could build a new pc and just use my old pc with new sound card to run rew,
                                            what do yall recommend?
                                            budget $300/$450
                                            would a net book work?
                                            My System
                                            ~ Onkyo tx sr805
                                            ~ Sony PS.3
                                            ~ Xbox 360
                                            ~ Polk RTi6 Rears
                                            ~ Behringer ep2500
                                            • kevinp.
                                              • Apr 2008
                                              • 107
                                              anything will work, you need a USB port for an external sound card. The standard mic in is not good enough, you need a line in input. I'm using the $30 Behringer UCA202 and it works just fine. A $40 Rat Shack meter and you're all set, or you can move up to calibrated mic (and pre-amp) for more accuracy.
                                                • 5202
                                                You can start without a PC and do it the old fashion way using a CD w/ test tones, a piece of paper, and Excel. It is a very worthwhile process to do once, so you can hear what you're seeing. But a computer greatly speeds up the process.
                                                Like Kevin said, with laptops you often need an external USB soundcard. I used to use a $40 one from Creative. Most desktop soundcards work fine. The laptop doesn't need much power to run; it is a fairly simple program.
                                                • FroDaddy
                                                  • 274
                                                  Wow do it manually? It takes me long enough to do it with a computer!
                                                  I grabbed an old Soundblaster Live card and used it. When I say old I mean the first SB Live they made Only once have I used a laptop; every other time I unplugged my PC and set it up in the room. The laptop had a mic in and it was fine, although I wouldn't use one to start out with. I already had measurements from a trusted sound card so I knew what to look for.
                                                  I wouldn't buy a laptop nor PC specifically to EQ unless you're looking for an excuse to get a new one!
                                                    • 5202
                                                    I agree, I wouldn't buy a computer for this - unless you're buying a $50 one from craigslist or you have another legit reason for buying a computer.
                                                    It really doesn't take that long to do manually, depending on how many tones you're using. Probably 10 minutes. I used the Riva Test CD w/ the tones already corrected for the RS meter. Like I said, something good to do only once.
