I'm hoping somebody here can help me with an idea.
My house has a centralized equipment room in the lower level, distributed throughout the whole house. Therefore, for the two most important A/V zones, the theater and the living room, there is an in-wall conduit for each from the equipment room to the zone room. I think it's 1.5" conduit or so, and each of the conduits is estimated a little more than 50' long. Problem is, those that built the house didn't leave any runner ropes in the conduit to pull through.
I've already tried the technique of tying a washer at the end of a string and "sucking" it through from the other end with a vacuum. Problem is, this is flexible metal conduit, and I think the low pressure suction is letting ambient pressure air to come in through the little ribbing gaps along the entire length, that allow it to flex and bend. So I'm getting very low suction at the other end, and it's not sufficient to pull the string and washer through.
I've also tried using three different types of push rods--one metal wire, one nylon wire, and one a flat metal rod. For each of these, they go so far into the conduit, then hit what is probably a bend somewhere down the line and stop. (I've tried jiggling and conjoling it to go through... no joy)
The conduit to the theater already had a Cat 5 cable running through it that carries an IR signal to my projector. So, I tied a string to the end and pulled the Cat 5 cable out, for the string to be a new runner rope. Problem is, when I pulled the string back through, pulling the Cat 5 and a new runner string, it broke under tension, and I couldn't reach inside the conduit and get it. So I need to use a stronger runner string/rope, but now I have a conduit that I need to run cable through, that doesn't even have the cable that it HAD in it last week!
:M :M :M :M :M :M :M
So, any suggestions, guys, if how to make this happen? How do I get cable through a 50-60' conduit like this? (Basically need to run Cat 5 or Cat 6 cables through... eventually I'll be running HDMI video through them, extended by Cat 6 cables)
