I'm in the planning stages of a new reference speaker to replace my venerable Modula MT. This will be a 3 way design, what I've decided on already is:
Tweeter: Peerless DA25TX
Midrange: Peerless NE149-8
Woofer: ??? with about 2-2.3 cu ft to work with
Crossover/Amplification/driver eq: Hypex FA123 plate amp: 125wpc @ 4ohms, 15 biquads per channel
Desired woofer/mid crossover: 300-400hz (in hopes of mounting the woofer near the floor, mitigating floor bounce/allison effect)
A bit of context about the rest of my system that is relevant:
I know this is a lot of preamble! But, I believe context is important and may help inform the choices. Hopefully you're still with me!
Where I am torn is the bass section. I have on hand a pair of Peerless SLS 12" drivers; these are oddball sample drivers I bought from a former PSB engineer. They appear identical to the 830669 except for a double stacked magnet and possibly additional coating on the back of the cone. I also have 4 x of the nomex 830869.
I am leaning to using the SLS 12" drivers, but am a little leery of crossing them so high. I am also open to spending money if the upgrade is enough of an improvement, but am stymied by lack of wide experience with the contenders, and hesitation over the relatively low amount of power available (125w) to the woofer section. I have considered a variety of upgrades to the Peerless drivers, from the RS270P-4 and NE265-4, to SB34 and SB29 NRX, even the Satori and Motus 8" drivers. My priority is musicality with these woofers over output, HT I have well covered with the 3 subs.
At this point I feel like I'm stuck in analysis paralysis, and would welcome any input. What would you do in my shoes? I am open to suggestions here both in terms of woofers used and my general approach to the mid/woofer crossover. TIA to anyone who takes the time!
- Sources are all digital through a nad t758 receiver acting as preamp
- Same receiver provides DIRAC room correction for all channels
- The receiver's bass management is unusual in that it uses symmetrical LR4 slopes for low & high pass
- because of this, I'd prefer both the new 3-way and the subwoofers to be flat to at least an octave above/below the XO point, which I'd like to set at 40-50hz.
- So, I'd like the 3-way to extend (with some light eq if needed/possible) to 20-30hz in-room
- the 3-way will be crossed to 3 x 12" Rythmik servosubs, these will be corner loaded and optimized with a minidsp and Multi-Sub Optimizer
- the room is fairly small, acoustically treated, and gets generous room gain. Listening distance is 12ft. Speakers must be toed-in aggressively due to closeness of side walls
