This test will cover the basic capabilities of a very inexpensive AK4490 DAC from Breeze Audio. The test sample was provided by Renron, and he's posted about this little guy in the Digital Audio section of the forum.
Let's start off with the 20Hz to 20kHz frequency response at -6 dBFS:
The result is within a quarter of a dB from 20 Hz to about 12kHz, but rolls off within the top octave substantially, being down almost 4 dB at 20kHz relative to the passband level.
Let's get a bit of an idea of what's going on in the low level area looking at an averaged FFT with signal at 1000Hz and -60 dBFS. (one wouldn't just want to look at the output with no input signal, as many DACs have muting circuits that kill the output completely to reduce the measured noise)
Knowing this is a Delta-Sigma DAC, it's pretty likely that the spuriae below -110dB are idle tone artifacts. That's at a very low level, so quantifying the audibility is difficult.
Next, we'll look at 50Hz with an input level of - 6dBFS -
Probably a true 2nd order harmonic at the -96 dB level. There's also a tiny bit of line frequency related noise at 120Hz- very low in level at -120 dB. But there is a fair amount of repeating stuff at 50Hz intervals that is not random noise.
What about the low level -90 dBFS 1kHz test? (toggling the LSB)
It's quite recognizable, though with some DC offset from the zero position. Typical Gibbs ringing is not visible readily visible.
Here's a somewhat better example in a $1K DAC, the Cambridge Audio 851D.
What about high frequency intermodulation and image rejection? The 19+20kHz CCIM test will sort that out, with 19 and 20kHz driven each at -6dBFS.
Things are not really right with the AudioBreeze DAC. This is what the output from the DAC looks like in scope mode:
This is what it should look like, with the proper levels and beat summing:
This is what the FFT looks like, and this tells the tale...
There is virtually no image rejection, and very high levels for the aliased image frequency set. Yes, the CCIM distortion side bands and 1kHz difference frequency are essentially non-existent (very good), but the image behavior is not acceptable.
OTOH, otherwise, it still may be one of the world's best $82 DACs... :W
