I have been in the process of deciding to build a pair of Statement II speakers for quite a while. I am at the point now where I am ready to get the project started. I plan to make some modification to the original Statement II Design. You might call it a Statement II in an Anthology size box. A 4’ tall MTMWW driver arrangement with Statement II drivers and crossover. I plan to keep the driver spacing and baffle width as designed, except for the placement of the top woofer and the volume will be reduced.
The plan is to Have ¾ round over on the front, sides and bottom of the front baffle made out of solid wood trim and the rest of the surfaces will be finished with paper backed veneer. The veneer finish will have a Shellac base coat with a Polyurethane top coat.
The speakers will have a rear ported cabinet.
I have a completed several wood working projects since I bought a contractors table saw back in 1998, and have added a router table, planer, jointer and band saw since then. So I have some woodworking skills and tools needed for the project. I am an Electronic Technician by trade.
The Medite MDF ½ and ¾ sheets are in the shop waiting.
First lesson learned do not unload a sheet of ¾ MDF from the roof rack of your car by yourself.
Drivers and Parts yet to be purchased.
I have attached a SketchUp Still.
