Introducing Rotel's best ever Home Theater Component, the RAP-1580
  • Kevin D
    • 4601
    To be shown at Cedia next week and launching in November.
    Separates Performance in a Single Chassis
    Will have Atmos 7.1.4 and HDMI 2.0/HDCP 2.2.
    More info to come next week!
    Kevin D.
  • jam200
    • Jan 2009
    • 93
    What does RAP stand for?
    • Kevin D
      • 4601
      I would imagine Rotel Amplified Processor. No tuner, so not a receiver.
      • JDH
        • 270
        Hopefully they will also get around to updating the RSP-1572 with a replacement too.
        JDH
        Bits of HT & 2ch Stuff: Rotel, Pro-ject, Oppo, Bel Canto, Elektra Audio, Benchmark, Panasonic, DSPeaker, Epson, Slim Devices, Belkin, Philips Pronto, Harmony, URC, Sennheisser, AKG, HTPC under development, KEF, Whatmough, Definitive Technology & Pardigm Signiture speakers
        • Frank Helmling
          • May 2009
          • 54
          A tuner is obsolet! Analog Radio at home is almost inexistent in today's homes and digital music stream is available elsewhere (Streamer, Blurayplayer...). Seams like Rotel is back in A/B amplification (visible heatsinks). Anyway, Kevin:
          A headphone output und the HDMI drop out issue are the main Points to be recognized. The EQ is already superb, still an expanded DSP-section with adaptable highpassfilter to suit the rooms limitations (avoiding first roommode in small rooms for example would be of interest.
          Greetz from Monnem (Mannheim)
          Frank
          • Audio_ElF
            • 271
            So replacement for the RSX range?
            Any news about Atmos and HDMI2.2 upgrade for RSP1582?
            • jam200
              • Jan 2009
              • 93
              I think that will be announced as well. Have heard that the HDMI 2.0a and HDCP 2.2 upgrade for the 1582 is coming in September.
              • Audio_ElF
                • 271
                Another thought... how definite is the November launch date... as I recall the RSP1582 was 6 months or more later than the promised launch date...
                • jam200
                  • Jan 2009
                  • 93
                  Here's the most current information on the Rotel RAP-1580 from Crowne Audio's website (www.croweaudio.com).
                  Rotel RAP-1580 7.1.4 Integrated Surround Amplifier Processor
                  RAP-1580 is the ideal home theater solution for those who don’t have space for separate components, yet still desire uncompromising performance. It is an ultra-high-performance multichannel, integrated amplifier with surround processing that brings music and movies to life in a startlingly vivid way. Sporting the latest HDMI2.0a hardware and Dolby Atmos 7.1.4 processing, its amplifier section is built upon a powerful linear design with 7 x 100 watts per channel, all channels driven into 8 ohms, anchored by a massive Rotel-made toroidal transformer. While it may be compared to ordinary AVRs, it really is in a class by itself. Please hook it up to your best speakers in stereo and listen for yourself. RAP-1580 utilizes high performance Wolfson 24bit/192kHz DACs for all channels. These low noise, audiophile quality DACs are supported with premium-grade audio parts in circuits tuned by Rotel’s acoustic engineering team in the U.K. Inputs include 8 x HDMI video inputs with 2 x HDMI video outputs all supporting 4K video, with 3 of these inputs and both outputs enabled with HDCP 2.2. There is a seven-inch TFT display on the front panel to provide easy adjustments to all audio and video parameters without the need to turn on the television or video projection system. This makes it ideal for set-ups when the equipment rack is located separately from the video display. A full suite of integration features are also on board. Other features include a front panel HDMI input with 4K video pass-through, front panel iPod USB input with 2.1A charging and integrated APTX enabled Bluetooth technology for higher fidelity. The RAP-1580 also includes a PC-USB input supporting 24 bit / 192kHz audio, a MM phono stage input, CD input, XLR balanced input, Tuner input, AUX analog input and multichannel input. Rack mount ears are included. Rotel's RAP-1580 is simple to operate, powerful, flexible and refined. It is a state-of-the-art single chassis audio/video component that outperforms most separates. In an age of deflationary pricing, RAP-1580 lets you step customers UP to a higher quality experience. Features: 6 Wolfson WM8740 24-bit / 192KHz HiFi DACs • Analog BYPASS mode for analog inputs passes audio directly to output w/ no DSP processing • 10 band parametric PEQ • 7 rear panel and 1 front panel HDMI 2.0a inputs capable of 4K video pass-through • 2 HDMI 4K video outputs (one with ARC) • HDMI Bypass when in standby allowing the HDMI from source to TV when RSP in standby mode • OSD setup and status on front TFT and HDMI out • PC-USB supporting 24-bit/192kHz audio • Front panel USB input supporting iOS devices with 2.1A charging • Phono stage input (MM) • CD, Tuner and Aux analog inputs • Multi Channel input • XLR Balanced input • Bluetooth with aptX • 3 source independent 12V trigger outputs • Wired IR Remote input • RS-232 interface for automation system control • IP Network interface for automation system control • 2 IR Output connectors for IR pass-through • 4U cabinet • Finishes - Silver and Black • Dimensions (W x H x D) 431 x 192 x 470 mm , 17 x 7 5/9 x 18 1/2 in • Weight (net) 22.8 kg / 50.27 lbs • Rack mount included.
                  • hometheaternut
                    • Oct 2014
                    • 13
                    [ATTACH=CONFIG]26457[/ATTACH] Look at this Bad Boy! Rotel's Back!!!!!!!!
                    • madmac
                      • Aug 2010
                      • 3122
                      Originally posted by hometheaternut
                      [ATTACH=CONFIG]26457[/ATTACH] look at this bad boy! Rotel's back!!!!!!!!
                      oh my !!!
                      Dan Madden :T
                      • Patrick Butler
                        • Jan 2014
                        • 164
                        Hi Audio_EIF,
                        The RAP-1580 is in production, and we are in the process of finishing up the software. Things are looking good for a November launch, provided the software is bug-free. Sounded great at CEDIA last week.
                        Patrick
                        B&W Group North America
                        • Mikael
                          • Aug 2007
                          • 379
                          Hi Patrick
                          Is it november for europe aswell? And what about dts x?
                          Are there preouts for all channels or only the last four?
                          Best Mikael
                          • Patrick Butler
                            • Jan 2014
                            • 164
                            Hi Mikael,
                            While I can't speak for Europe, November is probably close to the correct launch month. The RAP-1580 will include Atmos and DTS:X processing. Pre outputs are included for all channels.
                            Patrick
                            Originally posted by Mikael
                            Hi Patrick
                            Best Mikael
                            • Mikael
                              • Aug 2007
                              • 379
                              Hi Patrick
                              Thanks are the 7 power amp asigneble as you wish or fixed.
                              How does it sound, like an RMB-1555?
                              Best Mikael
                              • Patrick Butler
                                • Jan 2014
                                • 164
                                Hi Mikael,
                                At present, there is a limited degree of flexibility in assigning power amplification channels to different speakers. As an example, there will be a configuration mode where you can bi-amp the main Left and Right channels, which using the remaining amplification to finish a 5 channel system. Sound quality is excellent, however I have not directly compared it to an RMB-1555.
                                Patrick
                                Hi Patrick
                                Best Mikael
                                • Mikael
                                  • Aug 2007
                                  • 379
                                  Sounds nice. But I ment if I buy two RB-1582 for left and right front and the sides speakers. Can i then asign the internal 7 amps for the rest of the speakers in a 7.1.4 setup?
                                  • Patrick Butler
                                    • Jan 2014
                                    • 164
                                    At this point no, but that might changed with a firmware update.
                                    Best,
                                    Patrick
                                    • Mikael
                                      • Aug 2007
                                      • 379
                                      So just to be clear for now the 7 amps are for the normal 7 channels and then you a 5 ch amp or 2*2 ch amp for the 4 inceiling ch. And if I want to upgrade front l/r ch. I need that amp and amps for the inceiling ch.
                                      Best Mikael
                                      • Mikael
                                        • Aug 2007
                                        • 379
                                        Hi again are rotel coming with a RSP-158? with atmos and dts x.
                                        • Patrick Butler
                                          • Jan 2014
                                          • 164
                                          Correct.
                                          Best Mikael
                                          • Patrick Butler
                                            • Jan 2014
                                            • 164
                                            Hi Mikael,
                                            Rotel will introduce an RSP with Atmos and DTS. Unknown when it will be coming to market.
                                            Patrick
                                            • Mikael
                                              • Aug 2007
                                              • 379
                                              Thanks Patrick.
                                              • peplogic
                                                • Nov 2016
                                                • 12
                                                Hello all. Does any one know how many watts per channel will be supported? I am looking at pairing this with Martin Logan Ethos and im hoping to deliver more than 100 watts to the left and right.
                                                Any help is appreciated
                                                -Pep
                                                Sent from my SAMSUNG-SM-N920A using Tapatalk
                                                • jam200
                                                  • Jan 2009
                                                  • 93
                                                  100 watts per channel at 8ohms.
                                                  • peplogic
                                                    • Nov 2016
                                                    • 12
                                                    Does that increase for 2 channel? An exmple would be the arcam avr 550. Its 90 watts per channel but the litterature on their sites says...it bumps to 110 for 2 channel audio.
                                                    Thx
                                                    Pep
                                                    • jam200
                                                      • Jan 2009
                                                      • 93
                                                      Not sure about two channel wattage. That's a question for Patrick Butler.
                                                      • Patrick Butler
                                                        • Jan 2014
                                                        • 164
                                                        Good question about power. 100 watts per channel into 8 ohms, regardless of whether you are powering 1 speaker or all 7.
                                                        Best Regards,
                                                        Patrick Butler
                                                        • peplogic
                                                          • Nov 2016
                                                          • 12
                                                          Best Regards,
                                                          Patrick Butler
                                                          Patrick.....thx. could you speak to Parametric Eq vs Room Correction. Why didnt Rotel include room correction?
                                                          Is there an advantage to Parametric eq?
                                                          Thx
                                                            • 5673
                                                            Hi, peplogic......
                                                            and welcome to our forum.
                                                            your ML's have a powered sub....correct?
                                                            much of the power required to drive speakers is taken up to produce the lower frequencies.
                                                            in your case, this is working in your favor.......however......
                                                            your ML's (which i have recently heard at Capital Audiofest) are electrostats.
                                                            it is my personal experience that electrostats (which i would own if i had a listening room that would accommodate the square footage they need to perform to there potential) typically respond V well to an abundance of reserve power.
                                                            from the ML Ethos User Manual:
                                                            What size amplifier should I use?
                                                            We recommend an amplifier with 100 to 200 watts
                                                            per channel for most applications. Probably less would
                                                            be adequate for our smaller hybrids or when used in
                                                            home theater where a subwoofer is employed. Our
                                                            hybrid designs will perform well with either a tube or
                                                            transistorized amplifier, and will reveal the sonic character
                                                            of either type. However, it is important that the
                                                            amplifier be stable operating into varying impedance
                                                            loads: an ideally stable amplifier will typically be able
                                                            to deliver nearly twice its rated wattage into 4 Ohms
                                                            and should again increase into 2 Ohms
                                                            what they are saying is, to paraphrase in my own words:
                                                            • RULE# 1: there is no such thing as too much clean, distortion-free, brute power.
                                                            • RULE# 2: See Rule #1
                                                            despite the published sensitivity of 92 dB/2.83 volts/meter, they rate these as 4 ohm speakers.....that value being an average, not a constant & they will dip below that value in normal use.
                                                            to my knowledge, there are few AVR multi-channel amps that will delver the power and headroom needed to make the ML's deliver their true potential.
                                                            i suggest you consider a good quality 2-channel amp to power them.
                                                            also, do not get too hung up on published specs
                                                            typically, they are just numbers cobbled & embellished by marketing departments & seldom reflect the true actual capability of any amp. (no disrespect to Patrick whose help & information here is ALWAYS appreciated)
                                                            i have heard 300+ watt amps that hit like a flea, & 100 watt amps that smack like a nun's ruler.
                                                            as always, just my humble opinion, your mileage may vary.
                                                              • 5673
                                                              Originally posted by peplogic
                                                              [Rotel's] Parametric Eq vs Room Correction
                                                              peplogic, see Kal's Stereophile article on the RSP-1572 HERE
        • 5673
        regarding my comment on owning a set of electrostats.....
        my preference would most definitely be a set of refurbished Quad ESL-63's from Ken at ElectroStatic Solutions.
        i have yet to hear a more truthful reproduction of music from any other speaker at any price.
        i get to listen to Ken's Quads every year at Capital Audiofest.......this is him on the Left, along with Robin Wyatt (in the middle) of Robyatt Audio & with my two best audio dawgs & me at the 2015 show.
        also from the 2015 show....these may look familiar to peplogic;
        the ML Montis ($9,995), this room being one of the top three at that year's show, imho.
        • peplogic
        • Nov 2016
        • 12
        Does then1580 have a release date in december?
        Was it like this ruler Bill?
        • 5673
        the ruler.....yes
        the nun......uh.....maybe best we not go there
        • Patrick Butler
        • Jan 2014
        • 164
        Hi peplogic,
        We are waiting for an update on when we can expect the RAP-1580 to begin shipping. I'll make sure to make a posting when a date has been confirmed.
        Patrick Butler
        • peplogic
        • Nov 2016
        • 12
        Hi peplogic,
        Patrick Butler
        Patrick....I couldnt help myself.....I Placed an order for a unit yesterday!!!!
        Cant wait for it to show. It looks awesome
        -Pep
        • cooldude211986
        • Dec 2016
        -Pep
        Hi peplogic,
        Did you get any estimate on shipping dates? I heard the shipment will start in February.
        Hi Patrick,
        Any confirmation on dates? Been anxiously waiting to order one.
        Regards
        • peplogic
        • Nov 2016
        • 12
        Originally posted by cooldude211986
        Hi peplogic,
        Hi Patrick,
        Regards
        My magnolia guy says less than 30 days....al though not surenifbi believe him
        • peplogic
        • Nov 2016
        • 12
        Patrick.....any word on release dates? My magnolia guy is blowing smome smoke up my rear...lol
        Follow up question. Are there any specs for thisnreciever at 4 ohms?
        Thank you
        • Patrick Butler
        • Jan 2014
        • 164
        Hi peplogic,
        The Magnolia people are only telling you what we know, which changes with some regularity. Such is the nature of software design. 1 step forward, 1 step back and another sideways.
        I have been asking for 4ohm specs, and should have something for you soon. Launch date for the RAP will be towards the end of January, beginning of February. All the hardware design is completed, and I use a finished unit for beta testing software. Rest assured- the RAP exists, and we are working towards making the user experience great in every regard.
        Best,
        Patrick
        Thank you
        • BartG
        • Jan 2017
        Can you assign the internal amp for ceiling speakers?
        I am looking into upgranding my Marantz 7011 receiver to something much more powerfull to drive my speaker config 5.1.4
        Front B&W CM10s2 - Connected with Rotel RB-1590
        Surround B&W CM6s2 - Connected with Rotel RMB 1585
        Center B&W CM Center 2 s2 - Connected with Rotel RMB 1585 preferably byamping a free channel
        Ceiling B&W CM1s2 Was intended to use RMB-1555 but if I can upgrade the reiver for rap-1580 would be great
        Sub B&W DB1
        • peplogic
        • Nov 2016
        • 12
        Hi peplogic,
        Best,
        Patrick
        Patrick. Did u ever get a 4 ohm rating for wattage on the 1580?
        Thx
        Brad
        Sent from my LG-H820 using Tapatalk
        • Patrick Butler
        • Jan 2014
        • 164
        Hi Brad,
        I did! 7x150W, all channels driven, 20-20k.
        Patrick
        Thx
        Brad
        • peplogic
        • Nov 2016
        • 12
        Hi Brad,
        Patrick
        Release date?
