OnTheBench.key by Jon Hancock, on Flickr
The Cambridge Audio 651W is now my new go-to amplifier for small and portable for speaker measurements. I got spoiled by the Benchmark AHB2- the 651W isn't truly an AHB2 replacement, but it's as close as you have any right to expect for 1/3 the price! The 651W is rated for 100W per channel at 8 Ohms, 150W/ch at 4 ohms. I picked the 651W to try because of the positive experience I'd had with it's big (and much heavier) brother, the 851W, and because I was curious if it would really match the quoted specifications.
651w-si by Jon Hancock, on Flickr
651w-bl by Jon Hancock, on Flickr
651w-rear by Jon Hancock, on Flickr
Both balanced and unbalanced inputs are provided; binding posts are EU style with insulators blocking the banana jack receptacle, but they are easily removed.
Interior layout is fairly clean and well organized, with the power supply on the left, output circuitry in the center, and inputs and protection more towards the right.
651W_offen_t by Jon Hancock, on Flickr
Figure 1: Frequency response and channel Balance
FreuencyResponse+10dBV by Jon Hancock, on Flickr
No surprises here, extended flat response to beyond 50 kHz on the top end; at 80 kHz protection kicks in. (not shown).
Figure 2: THD+Noise @ 1kHz from 200mW to 100W using Balanced Input
CA651W_LevelSweepTHD+N_1kHz by Jon Hancock, on Flickr
Note, with this kind of steadily decreasing slope on the THD+N, this indicates that the major component is noise- note that the 651 drops steadily from a low 0.005% at 1W output to about 0.0007% at 50W output- this is very good performance, indicating a very quiet front end (including the balanced amp receiver) and low distortion in the entire signal path.
Figure 3: THD+Noise @ 20W from 20Hz to 20kHz using Balanced Input
CA651W_FrequecySweepTHD+N by Jon Hancock, on Flickr
Distortion stays low over a wide frequency range, rising slightly as is typical at high frequencies.
Figure 4: FFT 1Hz to 1kHz with 50W 1kHz output
1kHz_50W_LF_FFT by Jon Hancock, on Flickr
This is a good way to look at power supply noise in the output when driven by a moderate output signal; here, we can see that the maximum influence of power supply harmonics lies at -130 dB below the output signal- yes, this is a good clean number!
Shifting the measurement point of the FFT to the high frequency band, and looking at the signal harmonics,
Figure 5: FFT 1kHz to 30kHz with 20W 1kHz output
1kHz_50W_HF_FFT by Jon Hancock, on Flickr
We can see that the highest level is the 2nd harmonic at 2 kHz, which is over 110dB down in level 3rd harmonic just a bit below that, and higher harmonics all 130dB down or more. These values are getting close to the residual level of the instrument.
Going down to 50Hz for an output harmonic test, at about 50W output,
Figure 6: FFT 1Hz to 1kHz with 50W 50Hz output
50Hz_50W_LF_FFT by Jon Hancock, on Flickr
Here we see a mixture of harmonic distortion and power supply line frequency related noise, generally below -120 dB.
Last test is the combined 19kHz + 20kHz CCIF high frequency intermodulation distortion- peak level is correlating with a 50W sine wave, where the crests of the individual frequencies add up.
Figure 7: Scope 19kHz+20kHz CCIF output
CCIF_19+20kHzCA651W_Output by Jon Hancock, on Flickr
Figure 8: FFT 19kHz+20kHz CCIF output
CCIF_19+20kHzCA651W_FFT by Jon Hancock, on Flickr
The highest sidebands are down by about 105dB; the highest difference product (1 kHz) is down by about -115dB - both are very good numbers for a power amplifier.
In fact, the results on this test compare favorably with the $2,999 Benchmark AHB2...
Figure 8: Benchmark AHB2 Bridged Mono 100W peak output FFT 19kHz+20kHz CCIF output
FFT Spectrum 19+20kHz 100W Pk AHB2 by Jon Hancock, on Flickr
Now, if this isn't good enough for your $999, and you've got some change rattling around in your pocket, there's a German firm that will do mods and update a lot of parts in the power supply and signal path. Oddly enough, they don't offer on the site any before and after measurements that I could find.... :W
Positives:
Concerns:
- Power output: 100 W per channel into 8 Ohms; 150 W per channel into 4 Ohms
- THD (unweighted): < 0.001% 1 kHz; < 0.005% 20 Hz - 20 kHz
- Frequency response: 5 Hz – 80 kHz +-1 dB
- S/N ratio (ref 1W / 8 Ohm): > 90 dB (unweighted)
- Sensitivity: 1.5V rms unbalanced; 1.5 + 1.5V rms balanced
- Input impedances: Balanced input 38 k Ohm; Unbalanced input 68 k Ohm
- Power amp damping factor: > 125 at 1 kHz
- Trigger in: 5 – 12V AC or DC
- Trigger out: 12V DC @ 100mA
- Maximum power consumption: 750 W
- Idle power consumption (no signal): 45W
- Standby power consumption: < 0.5W
- Dimensions: 16.9" wide, 4.5" high, 13.4" deep
- Weight: 23.5 lbs.
Positives:
- Very low noise, very low distortion by all test measures
- Includes balanced and unbalanced inputs
- Compact size, good ventilation and good built quality for the price point
- control options for system power up and down, programmable via Standby control
- Low cost relative to performance
- Both Silver and Black finish options
Concerns:
- Binding posts are rather light weight and wiggly- banana jack inputs for binding posts are initially covered (but cover is removable)
- Won't impress your friends who are looking for Audio Jewelry with massive tooling
