Well, here I go, on the dark side again. I'd intended to hold off posting more about this or starting an "official development and build thread" until we had more film in the can, but as this paraphrase of a quote Steve Manning used in a recent email goes, I'm itching to get going and have a thread with a more clearly and narrowly defined focus than the thread I started kicking around these ideas for, which originally was just going to be focused on the low frequency design.
Everything is subject to change at this point, yet I think we've got a pretty good grip on things as they stand.
And that patience quote relates to the fact that their are two main build efforts going on- the official Translam design which has been briefly discussed, and my earlier "by hand" design, which will still get built and likely finished earlier. (our CNC vendor is having some teething pains getting his setup sorted out- this may still be a few weeks).
Part of my lack of patience is also due to some more listening checks on the one acoustic prototype, including with a Naim album I just came across that is really lovely, (if you like latin influenced female jazz singers- MadMac, you better listen up!)
You can get this in CD version, which is probably pretty nice, but I have the direct from Naim 24/192 download, sort of like getting the master tape. well, actually, a LOT like getting the master tape! Recommended, in fact, Highly Recommended. (some really nice subtle percussion, and excellent bass guitar work)
So- back to the Minerva Monitor.
This is a TAD inspired design (think Compact Evolution One) "stand mount" design using the Seas C18EN001 concentric Midrange/tweeter driver, with low frequencies handled by the combination of Wavecor SW223BD02 and ScanSpeak Discovery 26W/0-00 10" Passive Radiator. yeah, it's not hardly fair putting that LF combo up against the 6-1/2" ported woofer used in the Compact Evolution One, but then it wasn't fair putting the SW223BD01/2 up against the Eton 7" woofers used in the Indra either. Some would say, if you're not cheating, you're not trying hard enough.
Next, I'll recap the table saw design and a quick overview of the Translam version of the design Steve Manning has been working up, then summarize the state of crossover development and the reasoning behind where that stands.
I should mention Seas has their own stand mount design using the C18EN001 and the RO4Y 10" subwoofer; it's even smaller, and uses DSP in the Hypex plate amp for the LF to mid crossover and equalizing out the upper range response after the relatively simple passive crossover.
It's very compact, no question!
And if the electronics in the Hypex plate amp (A/D; DSP; D/A, UcD modules) are up to the quality standard you want, this might be a system to take a close look at. OTOH, for me, I can't bear the thought of running any of my DAC's into this for music. It might be really killer for HT, though- think a 2.1 system without the 0.1!
