Using cable jumpers with a B&W 703 speaker.
  • pbarata
    • Feb 2003
    • 175
    As suggested by 703 manual it's recommended that one can connect both the positive and negative of the speaker cable terminals to the woofers first, or to the tweeters first, it doesn't really matter. However, if the speaker cables are connected to woofer first, I find that the sound becomes a little bass heavy. If connect to tweeters first, then I find the sound of the highs over whelming.
    In each configuration there always a time mismatch with impact in overall sound.
    Thus, I've tried to connect one speaker cable to the upper binding post and the other to the bottom. This results in a more coherent sound.
    I've your tried?
    Any explanation for these results?
    Movies: Samsung LCD LE37A557, Rotel RSP-1066 & RMB-1075, Sony PS3, VdH D-102 Hybrid III interc, QED XT-350 & Supra Rondo 4x2,5 speaker cable, QED Qunex P75 coax, Monitor Audio Silver 5i/8i/10i speakers, REL Quake sub, QED Qunex SR-SW subwoofer cable, IXOS XHT458 HDMI, Supra LoRad, Isotek Mini Sub GII;
    Music: Rega Planar 3, Goldring 1042, Vincent PHO-8, Krell KAV-280cd, Krell KAV-400xi, B&W 703, Siltech SQ-28 Classic G5 (XLR), Siltech LS-68 Classic Mk2, Nordost Vishnu, QED Qonduit MDH6.
    • 2901
    Hmmmm that's interesting... I never really thought to do that... now I may have to try with a set of speakers............ It makes sense as that's then definitely equally travelling across the speaker (ie, there's no "longer" pathway).
    • pbarata
      • Feb 2003
      • 175
      I would appreciate to hear about your findings when you have the change to try. Meanwhile a friend told me that a French speaker’s manufacturer, Davis Acoustics, recommends such a configuration:
        Yup, I did this when I got my Valhalla which is shotgun cable, replacing my biwire Tyr.
        I started with the 804s and continue to do it today with the Vivids. The diagonal configuration is the best sounding of the available options and I use the Nordost jumpers as well ( Norse, not Valhalla).
