Hi folks,
Getting back into electric guitars after a long hiatus and thought I would build my own amp/speaker cabinet now that I have this other hobby to leverage. I may end up getting one of those iRig/Apogee Jam interfaces as a sort of "pre-amp" and then feed either a dedicated guitar amp or just one of my other DIY amps to drive a couple Dayton RS-180s. This is where you come in.
Everything I've learned building nice speakers and amps seems to be less relevant in the electric guitar world where distortion and overdriving are desired vs. shunned. As such, I thought a quick and cheap project would be to take two leftover RS180 drivers (one of which has a bad wrinkle near the phase plug) and put them side by side in a small cabinet. They're not really full range drivers, but then, guitarists don't seem to care all that much about flat response.
So... questions are:
1. Should I leave it open backed or enclosed?
2. Wire in series or parallel (probably series to put less strain on the amp)
3. Any sort of passive crossover required/desired?
4. Will I just blow these drivers quickly as they're not designed for this application?
Thanks for your thoughts!
