Now I have a new house and more room.
The design goal is:
- front firing (I do believe that it must be better to have the sound waves hitting you than reflecting of the floor)
- More than one sub for better distribution and avoiding room modes
- Quite small size so that they can fit beside the main speakers in front of the room
- A bit more focus on "speed" and the upper part of the frequency area than the very, very low part
- Focus on music usage, but also for movies
I will wait to se of the old sub will be replaced by the new ones or be used together with them.
The plan:
I'm planning to go for 2x rythmic audios 15" servo subs in a 3-4cubic feet enclosure (that's 85-115 liters). I have a hope that I sometime in the future will build a set of ardent, and the sub baffle will follow the same design, as shown here:
(I'm planning on a 10 degree angel of the subs baffle as well, just like the ardent - not shown in the picture)
I tried to add the picture directly - but the file management did not work on my iPad - impossible to do the drag and drop stuff - I'll fix it when back on the computer)
Outer size will be approx 60 high, 40cm wide an 50cm deep (deeper if the different between top and button is included since the sub will be leaning backwards)
Front baffle is planned to be built from 3 layers of 2cm MDF.
The rest of the sides of 1 sheet of 2cm MDF.
The bracing will be the same as the drawing from rythmik audio.
DS1501_Front_Firing_enclosure.pdf
Any comment are appreciated!
As mentioned, this build is for learning stuff. Due to this I will add a "lessons learned" section to this first post where I will add what I have learned during the build.
Lessons learned:
- Need a better, more stable router jig to create good holes
- A circle saw with guides (at least my festool saw) works great to create nice, straight cuts
- When a baffle consist of more than one layer, make the cutoff after gluing the layers together (or at least do not use the first baffle plate as a template for the other holes. When the baffle is angled that will be wrong on the third baffle - causing the wholes do not align well).
- Rabbit joints (as used here) is fairly easy to create and makes the box easy to assemble - but it might be a bit challenging to get them precise enough
- Remember to check what temperature the glue will work under (had to move the baffle after putting on glue and all the clamps, luckily I have a technical room connected to my wood-shop, and that room is nice and warm, so it was fairly easy to do this)
The design goal is:
The plan:
Lessons learned:
