Jensen 1071 Build
    • 1879
    Jensen 1071 Build
    Well the bug hit again ....... time for another speaker build. Since I had done a couple of 2-way builds already I wanted to try a 3-way design this time. After much looking around I decided to go with Troels Gravesen's Jensen 1071 . I was following some new designs here with interest that were not yet finalized (Mr. Marsh) but due his work commitments, very inconsiderate of them to not give him time off!, and my impatience, I went with the 1071.
    In the past I've typically finished a project before posting pictures, but decided to go ahead and post as I go this time. I've tweaked the look over what Troels did with his build. I have kept baffle dimensions, driver placement, and cabinet volumes all the same. I found Sketchup rather helpful when it came to keeping track of volumes and in particular all of the needed angles when it came to cutting material.
    So I started collecting parts, working on the cabinet design with Sketchup and picked up some wood and started making some saw dust this past summer and here is some of what I've been up to .....
    The cabinet design ......
    Click image for larger version  Name:	Overall Look 2.jpg Views:	9331 Size:	53.8 KB ID:	871088
    Another .....
Name:	Overall Look 3a.jpg
    The important parts .....
    Out of the box ....
    To be continued ....... Steve
    • 1879
    More Pics
    Setting up some shade for the 100+ degree weather we had over the summer .....
    SOME of the wood getting ready to be cut with some layout lines ......
    Keeping the lines straight ........
    More later .....
      theSven commented
      Editing a comment
      Early garage photos before SMJ Audio was started...
  • meb46
    • Jul 2010
    • 398
    Great stuff Steve, keep us posted on all your progress!
    • oneplustwo
      • Jan 2010
      • 666
      *Drool* Will this be the build to end all builds?
      Zaph SR-71
      Zaph ZDT 3.5
      Sunflower Redux
      12" Dayton HF sub
      CJD RS 150 MT
      Revelator bookshelf
      2x12 Guitar cab
      Corner loaded line array
        • 873
        Interesting, did you consider the Jenzen Illuminator with it's transmission line base cab and time alined mid 2 order design?
        I too was looking at these designs while I'm waiting for Jon to finish up the Ardents or maybe a 10" Death Star,(I'm just going to be patient). From reviews it's hard to get a sense of how good his xover work is and I think He needs to put out some matching centers for all those tower designs he cranks out.
        Anyways looks like a fun project and I look forward to your progress. :T
          • 15261
          Looking good! :T
          Cool Steve- looks like you've got a great project on your hands!
          Keep the pictures coming and let us know how it's going for you! I really like the 26W's - VERY clean woofers!
            • 1879
            Hi dar47,
            When I decided to pull the trigger on the 1071's (back in March) Troels had not come out with the Jenzen Illuminator yet, so it was not a factor. I had already started collecting parts when it was released. There is also the part of not being able to change the cabinets at all with the Jenzen line. Part of the fun for me at least is being able to put some of myself into the build. I am not at the point where I can design the entire project, so that leaves the cabinet, keeping in mind the important dimensions that the designer has called out. I did this with Jon Marsh's Modula MTM1's that I built a while back. I'm not sure what, if anything, my cabinet design changed, I don't have Jon's build to compare them with. I will say that I've been very happy with them and they have impressed anyone that has heard them .... Thanks again Jon.
            By the way I was pining after the Ardents as well ..... you win in the patience department.
            As for the xovers ..... I will have to wait and see. Troels seems to have a loyal following (for what that may be worth) and the builders of the 1071 all seem to be very happy with the results ... time will tell.
            Steve
            Last edited by theSven; 15 May 2023, 22:00 Monday. Reason: Update quote and htguide url
              • 1879
              Some more pics
              Finally had to build a cross cut sled for my table saw, seemed like the best way to deal with all of the different angles I had to cut. That of course was after having to build a new top for my Craftsman saw that had not miter slots for the sled .....
              Setting the blade with a digital bevel gauge made things fairly straight forward with pretty good results ....
              Getting things lined up for some biscuit joints ......
              As a matter of fact there are 154 biscuit slots per cabinet !!!! I think a CNC router would be much easier .....
                theSven commented
                Editing a comment
                Fast forward some years later and you finally got that CNC Steve Manning :-)
              • 15261
              I don't know which is more impressive- that there are 154 biscuit slots per cabinet, or that you've counted them! :W
                Wait, you're supposed to use more than one or two biscuits per panel? 8O
                Nice job so far! :T
                  • 1879
                  Jon I had no idea the count was that high until I ran out of biscuits from the first container that I bought and had to run back up to Lowes and get another one. Since there's a hundred per container I was a little surprised and did the count. Keeps the parts nice and lined up though .......
                    • 15261
                    That it does, that it VERY much does. I'd be using more biscuits on this current build, but that the angles of the top module limit the possibility. The bass modules will be different- more right angles, and more biscuits!
                    Also, I see you cheat, too, with one of my favorite roll out tables! (upper left corner)
                      • 1879
                      Of course I cheat ... all's fair in love and war and all that . Besides it saves on the back and keeps those pesky boards where you want them rather than binding and bouncing off your face at warp 9 speeds. Did that many years ago, thought I'd been kicked by a mule !!!
                        • 5568
                        If using the right tool for the job is cheating...
                        Did you use any inspiration for the new top, or just wing it? I've been trying to determine the best road to working with larger panels safely, and that's one option - however, it limits my ability to use the fence I have, so I'm curious. Haven't even looked to see what's out there.
                          • 1879
                          cjd,
                          I saw something over at BT3 Central where they are a big fan of my particular saw. Someone had done something very similar and I tweaked it a little for what I needed. I also saw the aftermarket riving knife setup which I purchased. It was the first I had found for my saw. The top gives me a lot more working areas and I can use the fence on both sides of the blade. I also added a better switch for easier access. It's not a Martin but it does a pretty good job over all.
                          Steve
                          Click image for larger version  Name:	IMG_1570_resize.JPG Views:	8226 Size:	81.8 KB ID:	857730
                          Click image for larger version  Name:	IMG_1576_resize.JPG Views:	8122 Size:	84.8 KB ID:	857731
                            • 15261
                            I love what you've done with your Ryobi! If I do any projects next year, I'll have to go look on the BT3 forum and check that out- it's been a while since I've been over there. And your miter jig is the cat's meow- I've been looking at one of those, but it just hasn't been urgent (yet).
                              • 1879
                              Thanks Jon ...... The miter jig was a birthday gift from my wife, I was tired of messing with the one that came with the saw trying to get an accurate cut. Once you square this one to the blade the rest is a breeze.
                                • 1879
                                More pics
                                Getting the sides and internal braces in place .......
                                Cutting the braces to final configuration .......
                                  • 15261
                                  Now this is what a build thread should look like.... I'd better take notes!
                                    • 1879
                                    Look Ma no glue ....
                                    Here are a few pictures of a dry fit of most of the panels and internal braces ....
                                    Here's where all those biscuits came in handy .... it let me put the cabinet together and move it around (within reason) without a drop of glue or clamps.
                                      • 16075
                                      You move fast.
                                        • 1877
                                        You know, it looks like you actually know what you're doing! I don't know how you get everything to fit so nicely. Amazing work!!! ;x(
                                        John
                                        John unk:
                                          • 5568
                                          Originally posted by Hdale85
                                          You move fast.
                                          Probably took pictures all summer and saved them up to make it LOOK like the rest of us are slackers.
                                            • 15261
                                            Boy, I hope that's true, or I'm going to quit DIY due to incompetence! :W
                                              • 15261
                                              John
                                              I think it's called "talent", or, maybe "skill".
                                              Some of us (yours truly included) have to make do with dogged persistence. :W
                                                • 1879
                                                Thanks for the kind words guys ...... cjd has it figured out though and as Jon also pointed out I cheat. I started the actual building back in July. I figured I'd get things rolling along before posting so I would have something to actually show. I think I spend more time planning then I do building, as a result I don't move along too fast. I'm sure the neighbors think I'm nuts just standing there staring at the wood working out the next step in my head.
                                                John as for for the fit up ..... trust me there is still going to be some bondo to fill in cracks and uneven areas. Though I have found with the last few things I have built, not just speakers, drawing it up in Sketchup first has really helped with the quality of the build. It lets me visualize things and make adjustments without having to waste a pile of wood in the process. As a matter of fact I don't think I would have even been able to build these cabinets without using it. Take a look at this picture and look at all the crazy angles and you'll see what I mean.
                                                Steve
Name:	Cabinet Parts Larger Version 3a_resize.jpg
                                                  • 15261
                                                  Steve
                                                  Click image for larger version  Name:	Cabinet Parts Larger Version 3a_resize.jpg Views:	8004 Size:	94.5 KB ID:	857743
                                                  Yeah, it's one of those things that looks like it was designed either by a drunken sailor or Leonardo DiVinci- more likely the latter.
                                                  I feel the same way about planning, which is why though I had a fair amount in hand back in December when I ordered my 6 piecers of LBL ply, there's been a lot of Shark FX work since then, and rolling changes as I get inspiration or see things differently.
                                                  Last edited by theSven; 16 May 2023, 11:44 Tuesday. Reason: Remove broken image link
                                                    • 1879
                                                    I have not heard of Shark FX is that a Mac specific package? It looks like it is a little more serious than Sketchup.
                                                    One of these days I'm going to have to try some LBL ply. I mostly use Baltic Birch and mdf for my builds. I've looked around, but the closest I could find any LBL was 2 hours away in Richmond.
                                                      • 571
                                                      Steve
                                                      I like it...very nice work you are doing. I'm relating to your build because I'm also working on a Troels project...one of the Jenzen Seas designs. I've been working on it on and off since May. It's my first build so I was also accumulating pics before I start a build thread. I've had the same thoughts about my neighbors...I ponder my next moves quite a bit :W Good luck with the project!
                                                      Scott
                                                        • 1879
                                                        Scott
                                                        Hi Scott,
                                                        Thanks for the kind words ...... Which one of the Jenzen's are you doing? When do we get to see some pictures?
                                                          • 571
                                                          Hi Scott,
                                                          I'm doing the Jenzen NEXT T25 with the CA26RFX woofer in a ported cabinet. I'll detail it with pics when I start my thread (hopefully soon). These started out to just refurbish a pair of RTR 300d speakers with new baffles for my brother but that didn't sound like fun so it turned into a complete rebuild...it's been quite fun. A couple teaser pics of the drivers and a sketch of the speaker.
                                                            • 15261
                                                            Shark FX is both PC and Mac, but I run the Mac version. It has a high degree of interoperability, due to being able to work with file format from other programs (AutoCAD, Sketchup, Catia, etc) and standard exchange formats like STEPS. I was a long time AutoCAD user in the old days. Shark and ViaCAD are descended from a CAD program (Concepts CSI) that developed the automatic cursor alignment techniques used and licensed by several other CAD programs. ViaCAD provides most of the same design functionality, but not the complex rendering capability of Shark FX.
                                                            It's probably overkill, realistically, for speaker design, but I like the software a lot. Model to sheet functionality is quite useful, with a decent printer.
                                                              • 1879
                                                              Click image for larger version  Name:	DSC_0114_sm.jpg Views:	7921 Size:	98.1 KB ID:	857744
                                                              Click image for larger version  Name:	rtr_jenzen_sketch.png Views:	8105 Size:	39.9 KB ID:	857745
                                                              Cool Scott, I'm looking forward to your thread.
        • 1879
        Click image for larger version  Name:	InventorImport.jpg Views:	0 Size:	264.8 KB ID:	936745
        Thanks Jon, I'm familiar with AutoCAD and Concepts from work, though have not used them. I'm definitely a CAD neophyte but have enjoyed using Sketchup. I would like to put together a CNC router at some point, that may force me to get a little more serious in the CAD world.
        • AdelaaR
        • Dec 2010
        • 480
        Wow man ... amazing work so far.
        Mmm ... biscuits
        • 571
        Steve, thanks for the inspiration...I started my build thread
        • 1879
        On my way over to look .......
        • 1879
        Pics
        Checking out port tube fit .......
        Cabinet starts getting some glue .......
        • 1879
        Cabinet Dampening
        Troels design called for using bitumen and felt on the cabinet walls for dampening. After discovering that the type of felt he uses is tough to find in the US, and not wanting to deal with the smell of the bitumen, I decided to give an idea of Tony Gee's over at Humble Homemade Hifi a try .... carpet tile.
        It took a while to get everything cut and glued into place but it has made a big difference with the knuckle test on the walls.
        • 571
        Great job with the carpet tile... :T What did you use for the adhesive?
        • 1879
        Thanks ...... I used Loctite Pro Line Premium Construction Adhesive and threw some staples in to hold things in place will that set up. Seems to be holding pretty well so far.
        • gbegland
        • 233
        Make sure to use some 2"+ rigid fiberglass or Bonded Logic inside the cabs behind the mid and woofer. Looking excellent so far. Thanks for all the build porn!
        Greg
        • 1879
        Greg
        Thanks Greg. I was thinking about using some extra wool stuffing from Madisound that I have for the mid. cabinet and picking up a 5 lb bag of Acousta-Stuf from Parts Express for the bass cabinet.
        Steve
        • 1879
        Gluing on the final side .....
        Trying out the new sanding block for a little clean up .....
        • 1879
        After getting the second side on I was not satisfied with how the back sounded during a knuckle test, even with the carpet tiles added. The bracing worked very well on the sides but was not doing as good a job on the back. So I decided to add an additional layer of 1/2" mdf to the back area. This seemed to balance things out well, even though these things are starting to get a bit heavy!
        One cabinet with and without the extra layer.
