Sharkfin Statements (unauthorized)
  • bigbardmusiq
    • Jul 2010
    • 94
    Let Curt and Jim know that I appreciate them and there design! :T
  • bigbardmusiq
    • Jul 2010
    • 94
    Cutting wood...
      • 16075
      Looking pretty interesting, I love the base.
      • bigbardmusiq
        • Jul 2010
        • 94
        Yea thanks, it turned out pretty nice. The tubing is 1 5/8in capped and welded (my day job is welding). Those gold spikes were from a closeout deal at parts-express 2.99 or something.
        • bigbardmusiq
          • Jul 2010
          • 94
          Assembly:
            • 5568
            Is that all the bracing you put into the lower section? Or is there more?
            Looking quite interesting, regardless.
            • bigbardmusiq
              • Jul 2010
              • 94
              Yes, I thought about adding a brace from side to side.
              • bigbardmusiq
                • Jul 2010
                • 94
                Slots cut to curve the wood.
                  Are you going to fill the kerfs?
                  • bigbardmusiq
                    • Jul 2010
                    • 94
                    I am still debating that, I saw someone else fill it in with a woodglue mixture. My design calls for an additional 1/4in sheet of Walnut plywood to wrapped around the sides.
                      • 16075
                      Are you making a flat spot to mount the binding posts? Or will they be mounted on the bottom or something?
                      • bigbardmusiq
                        • Jul 2010
                        • 94
                        I planned on mounting the binding posts just above the base on the side. But now that you mentioned it, I might have to rethink it.
                        • bigbardmusiq
                          • Jul 2010
                          • 94
                          Continuing the cabinet assembly:
                          • Silver1omo
                            • Sep 2010
                            • 430
                            looking great!
                            Ivan.
                            My Statement monitors
                              • 16075
                              I think on the tunnels I would of like chamfered the outside edge so it gradually goes down to a point, would look a bit smoother from the outside. Might not of worked though? Of course that's just a detail thing and not something you'd see all the time. They do look quite neat though!
                              • bigbardmusiq
                                • Jul 2010
                                • 94
                                The binding post I chose worked like a champion! I will continue to use these in the future.
                                • bigbardmusiq
                                  • Jul 2010
                                  • 94
                                  I put a hold on the finish, I just realized I don't have a 3/4 round-over bit (only 1/2) and one of my RS225's is make a cracking noise when played near movie volume. I gonna put another piece of stainless tube in the tunnel opening or even a one inch walnut dowel piece.
                                  • john trials
                                    • 449
                                    Cool looking Statements!
                                    The crackling noise is probably grit in the voice coil area. I (and many others) had it on some of the RS drivers. Try some compressed air around the phase plug to blow it out. I used 20Hz and 30Hz tones along with compressed air to blow the voice coil area clean. The noises from my drivers were easily reproduced with 20Hz tones, so that was helpful in indicating when the driver was cleaned out.
                                    • bigbardmusiq
                                      • Jul 2010
                                      • 94
                                      is it possible to put too much air pressure on it and ruin something? And what's the best method for finding a 20hz test tone? I have a black eye peas song "boom boom pow" that seams pretty low in hz.
                                        • 16075
                                        Those look fantastic! That's sort of the design I had WANTED to go for with my original plan for my 4T's but ended up not slanting the top back, I wish I would of though as it looks soo good... I'm not sure I want to tackle another curved speaker though.
                                        • rdrowley
                                          • Sep 2010
                                          • 87
                                          Here is a place I have gotten decent test tones . They are compressed, so they aren't perfect, but they are pretty good.
                                          -Ryan
                                          • john trials
                                            • 449
                                            Test tones: I've used both the Bink Audio Test CD http://binkster.net/extras.shtml or if you have a computer hooked up to your sound system, you can generate tones with Audacity (you can make any frequency you want with this) http://audacity.sourceforge.net/
                                            For compressed air, I used one of those 'air in a can' things...like this: http://www.uline.com/BL_6955/Air-In-...Fcnc4Aod5xf8Xw You can get them at office supply stores.
                                            I tried two methods for cleaning out the voice coil area. One was the compressed air, which worked pretty well, but on a really stubborn driver, I used the air and then a shop vac (with the hose attached right over the phase plug!). The air was not going to damage the driver, but the shop vac was pretty risky! I would not recommend the shop vac.
                                            After I cleaned out mine, someone suggested aiming the driver downward and running test tones, using gravity (and if needed, compressed air) to help remove the grit. I did mine installed in the cabinets.
                                            • GPHammer
                                              • Jul 2010
                                              • 16
                                              Fantastic job, you are very talented
                                              • justphil
                                                • Nov 2010
                                                • 24
                                                I love seeing beautiful work like this.
                                                I hate how inferior it makes me feel.
                                                =P
                                                • bigbardmusiq
                                                  • Jul 2010
                                                  • 94
                                                  =P
                                                  Don't fill inferior, I won't attempt curved sides anytime soon. Way more work than I anticipated.
                                                    • 16075
                                                    Yes it's a ton of work, If I had a proper shop like that though I think it would of made a difference in how mine turned out.
                                                    • Biermann
                                                      • Aug 2009
                                                      • 51
                                                      Nice work.
                                                      Do you plan to fill the inner voids of the kerf cut outer sheets?
                                                      • bigbardmusiq
                                                        • Jul 2010
                                                        • 94
                                                        Originally posted by Biermann
                                                        Nice work.
                                                        Nope, I had to bondo the kerfs near the mid tunnels and the false bottom (my crossover compartment). The very top is a half inch mdf covered by 1/2 in hardwood. the sides have a 1/4in walnut veneer board wrapped around the mdf.
                                                        The bass from these statements is simply remarkable, i just can't imagine anything better, I feel like I'm hearing a different dynamic sounds of bass or a Hz frequency that my subs aren't hitting. I know that sounds strange, statements are only suppose to go in the 30hz range but there's something I'm feeling from these that's reaches deep ;x( . This has prompted me to rethink my subs right away. I will give a official review later when I'm finished.
                                                        • bigbardmusiq
                                                          • Jul 2010
                                                          • 94
                                                          Whats good for wiping the saw dust off the rubber parts of the speaker? Windex?
                                                          • Jed
                                                            • 3617
                                                            Great job! :T
                                                            • joeybutts
                                                              • 476
                                                              Those are beautiful....
        • 3223
        VERY pretty! :T
        • tpremo55
        • 113
        Gorgeous speaker! Wonderful finish.
        ...I hope you enjoy them as much as I have.
        • tpremo55
        • 113
        damp rag. I'm chemical adverse on surrounds. I also leave/put the drivers back in the box when making sawdust. I've never had anything that a damp rag wouldn't clean up.
        • bigbardmusiq
        • Jul 2010
        • 94
        thanks, i was scared to rub anything on them!
        • Silver1omo
        • Sep 2010
        • 430
        Really gorgeous!
        Ivan.
        • richnen
        • Jul 2010
        • 117
        WOW! Those look amazing!
        Great job!
        Seas Idunn
        ZA5.2
        ZA5.3CC
        SB Acoustics 12" sub
        Statement Monitors
        CLD M5B
        • bigbardmusiq
        • Jul 2010
        • 94
        Great job!
        Well Thanks you guys are making my day. This project took all of my free time outside of work for the entire month of November, and after hearing them I have to say it was worth it.
        • cbark
        • Jan 2010
        • 97
        Damn! Great looking, and they have to sound amazing to boot! You cannot buy anything that looks that good in my opinion.
        ...were technology and old world craftmanship come together.... :T
        Well worth whatever time you spent.
        • Txgrizzly
        • Jun 2009
        • 235
        Dang!!! those look great, how much did one of them weigh after the bondo and everything? :T
        • bigbardmusiq
        • Jul 2010
        • 94
        Curt just announced that the cabinets can be made 20% smaller with the new unshielded drivers and still work. I was able to weight mine before speaker install and with the bases they came in at 105 pounds .
        • Txgrizzly
        • Jun 2009
        • 235
        So probably 125 per speaker, that is pretty solid!!!
        wonder if Curt is going to adjust his drawings to the new dimensions? 8O
        • 3223
        The CAD drawings were done by a friend of ours and I'd hate to impose on him again. So, I'm not sure if we'll have new drawings or just suggestions to reduce volume if the builder desires a smaller cabinet. Note that you don't have to reduce the volume, it'll just work at a smaller size now.
        Of course, don't forget what the "Y" in DIY stands for. :W
        • mgrabow
        • Dec 2009
        • 30
        Nice job, and nice tools...
        • snmhanson
        • Jun 2010
        • 194
        Very beautiful speakers. I am partial to curved designs and these are some of the best I've seen. I am going to keep this thread flagged for inspiration in my future builds. Did you use hardwood or veneer over MDF for the outer baffles? Also, did you chamfer the inside of the woofer and mid cutouts?
        Matt
